Tang Band W5-704 and a TB ceramic tweeter - Page 3 - diyAudio
Old 25th September 2012, 06:03 PM   #21
19L tuned to 36Hz gives a nice tapered bass response (Zaphs parameters)
down to the mid 30's, but you can't expect a lot from 3mm excursion,
and 5", unless you have a small room.
No criticism intended, but a good 6.5" is always going to outperform
a good 5" in a ~ 20L box, regarding undistorted low bass SPL, but
a 5" can go a little lower extension wise, but less efficiency and SPL.
rgds, sreten.
Old 26th September 2012, 08:27 AM   #22
imagios is offline imagios  Czech Republic
Originally Posted by Allstar View Post
Looking forward to seeing where your design heads too Imagios, please keep us updated.
Well so far Im solving a tool issue, since cutting out circles in the wood is not a easy doing, if you want to have it done decent...but that is a issue I discuss here: Dremel Trio ... sufficient tool?
in the mean while, Im thinking whether not to get the MatCAD plugin from Martin J. King, and look for a transition line result for the driver,... just out of curiosity.
But any way I will keep you updated
Old 26th September 2012, 09:10 AM   #23
Allstar is offline Allstar  United Kingdom
That's actually quite encouraging. I do have a small room ( with some trapping ) and the design is intended to be used at consistently moderate levels. I have a set monitoring level of about 83dB SPL and listen on axis at about 1 meter.
The size and shape of the cabinets is quite intentional so when I inevitably have a go at version II, I agree 6.5" woofers would likely be a better fit. Nonetheless I'm looking forward to seeing what can be achieved with the W5 704D ( I'm pairing it with a Vifa DX25TG09-04 incidentally ) and will certainly be trying the tuning you've recommended.
Old 26th September 2012, 09:21 AM   #24
Thanks.
Yes, I toyed with the idea of using a transmission line and Martin's worksheets, but being new to designing speakers from scratch I felt the learning curve might be a bit steep for me. At least for now.
Old 30th September 2012, 07:48 PM   #25
Thanks.
Yea for me its the same therefore I start with the vented box
(Still the transition line is something that I would at least like to see simulated)
Old 2nd October 2012, 06:49 PM   #26
OK I have go the MDF today, since they had no 15mm I have gone for the 18mm MDF, nice pieces good quality, but I made a stupid mistake and se the parameter wrong, now the internal volume is 14,5l and the pieces need to be adjusted to really fit together...
I ended up in a situation when from each corner of the desk I have to take 9mm so that the plates lock together... and I will have to do that with the small Makita I ordered...
Well a lot of work is ahead, I will than measure the real inner volume and redo the simulations, really a nice start.
Old 3rd October 2012, 09:44 PM   #27
OK the measuring tool arrived today I could measure the parameters.
here they are:
first one
D 125.0 [mm]
Re 6.18 [Ohms]
Fs 47.78 [Hz]
Zm 39.38 [Ohms]
BL 4.89 [N/A]
Qms 2.801
Qes 0.521
Qts 0.439
Vas 34.960 [liters]
L10k 0.32 [mH]
n0 0.70 [%]
dBSPL 90.54 [1W/1m]
Ms 6.71 [grams]
Cms 1.65 [mm/N]
Second one:
D 125.0 [mm]
Re 6.14 [Ohms]
Fs 49.12 [Hz]
Zm 41.47 [Ohms]
BL 4.90 [N/A]
Qms 2.777
Qes 0.483
Qts 0.411
Vas 36.220 [liters]
L10k 0.31 [mH]
n0 0.85 [%]
dBSPL 91.38 [1W/1m]
Ms 6.13 [grams]
Cms 1.71 [mm/N]
now in diagrams:
now I hope I do not overspam it here but here are some more pictures:
Old 3rd October 2012, 10:17 PM   #28
OK now as you might see the measured parameters are a way from the datasheet parameters, I even recalibrated the instrument twice and remeasured the speaker, with the same result... now it seems to screw up my project and I have already catted MDF pieces...but with the measured parameters this is a far from what I planed
Old 4th October 2012, 05:21 AM   #29
Thanks for the update imagios, sorry to hear about the problems. Odd that your Vas measurement is about three times the value of others I have seen. If it were me i'd be suspicious of that.
Old 4th October 2012, 07:22 AM   #30
At this moment I really dont know what to do, its like I would measure a totally different driver. There must be a error in the measurement, I can not imagine TB would have such a difference between the datasheet and reality...
Im open for suggestions, any one having similar experience?
Tang Band W5-1880 briandk Full Range 16 1st November 2012 09:45 PM
Tang Band W8-1808 / TB ribbon tweeter / Eminence Alpha 15A in OB with U-frame superlian Full Range 3 4th September 2011 12:11 AM
Tang Band W5-1685 BIB? geepee Full Range 5 16th August 2010 01:00 AM
Tang Band W5-704D revelator Full Range 0 1st February 2008 07:26 AM
Tang Band w5-704s MITMechE Multi-Way 8 26th February 2007 03:38 PM
Copyright 1999-2017 diyAudio
