#11 |
Face it. On a desktop, you can get pretty good sound. Not fantastic. It is a hostile place. I have a small set of Fountek 85's that do OK for listening to lectures. If I want high fidelity, it will not be on my desk.
Take a hint from the studio folks. They most all sit at desktops now. Move the speakers up and out a couple feet. Most of them also have space behind the desk too, but you can do things with acoustic absorbers. |
#12 | |
There are arguments for and against wide dispersion depending on what one wants from the speakers: close monitoring of recordings or enjoying recordings in a "normal" reflective environment which is something of a challenge when one sits close to the speakers. |
#13 |
If you're afraid of damaging your speakers, you can easily protect them with grilles.
And if you sit on your desk you sit in close nearfield to the speakers. In this situation, there is no alternative in using wide dispersion speakers. Otherwise, the smallest change in listening position will change the sound dramatically. |
#14 |
My desk currently has piles of papers and books, a box, various electrical gadgets, mouse, keyboard, laptop,... which will block sound from drivers at desktop level. Speakers without grilles would get damaged pretty quickly.
#16 |
Easy answer : Sennheiser Canada Inc. - MX 980
Seriously decent sound reproduction. IMO 'easily' better than a wee box. Tangible bonus of no Audiophilia paraphenailia cluttering up ones' valuable workspace area. |
#17 |
Bare,
that is another way to look at the problem at the desk, I just couldn't ever get use to in ear headphones. If I am going to use headphones they are over the ear and not in it. But I do appreciate all of the feedback. Some is generic and some is very specific as to what you think the problems or opportunities are for nearfield loudspeakers. I am paying very close attention to what is being said here. Steven |
#18 | |
What can work is converting the stereo signal to binaural, adding the room reflections and using a head-tracker to stabilize the sources. Still leaves issues with bass but was a system I could have lived with when it was demonstrated to me a few years ago. Would make a nice DIY project. |
#19 |
Xenums:
![]() Triumph (or Biumph): ![]() ![]() ![]() Use a KG3100 for a fully amplified 2.1 set, but you may need to add volume to the Triumph to offset the chamber. Later, Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102 |
#20 |
I've been answering this question for myself and have examined almost all of the Cons listed above. My thoughts
Mid/high driver(s) at ear level....so given a standard desk height, that should put the drivers roughly 16" above the top and reduce destructive early reflections... Want directivity?.....dipole for the mid-highs...my choice would be B&G neo3 above Neo8 or if the budget allows, Neo10 on a narrow open baffle. 4-5" woofer with a sealed f3 around 80hz for the base/bottom. Cross the mid as low as you can, considering reality where power handling is concerned.....how loud will you really be using these at a desk? 8-10" sealed sub below the desk with an F3 somewhere in the low 30's......boundary and cavity gains under the desk will do the rest. In a nutshell....mini Martin Logans so to speak. |
| S11 OB - Revisiting Desktop OB design using Seas 8" and Tang Band Full-Range | gainphile | Multi-Way | 27 | 23rd January 2013 09:51 PM |
| loudspeaker enclosure design | davidel94 | Multi-Way | 5 | 9th September 2012 02:26 PM |
| Desktop Fullrange design help please? | mayhem13 | Full Range | 6 | 5th November 2010 11:36 PM |
| 2.1 Computer/Desktop Speaker Design | pirate121 | Multi-Way | 7 | 30th October 2010 02:15 AM |
| which loudspeaker design? | maghen | Multi-Way | 128 | 2nd October 2009 09:10 PM |
