Passive Low Frequency Filtering
Old 27th September 2012, 04:03 AM   #11
PeteMcK is offline PeteMcK
first thing I'd try is a 220uF or 270uF NP electro cap in series with the speaker & see how it sounds....
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 27th September 2012, 04:16 AM   #12
Melo theory is offline Melo theory  United States
Melo theory's Avatar
FMOD Crossover Pair 150 Hz High Pass 266-276
I LIKE YOU
Old 27th September 2012, 06:45 AM   #13
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
If you use a high pass what are you going to use for the bass?
if we had the T/S parameters for the woofer some of us could model it.
pictures please
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Passive Low Frequency FilteringHide this!Advertise here!
Passive Radiator for Low Excursion, Low Displacement & High Sens Woofer? goody75 Subwoofers 15 7th May 2012 08:07 PM
Passive low-pass passive for line input - 2nd part andreaemme Analog Line Level 0 9th June 2011 02:04 PM
Passive low-pass passive for line input andreaemme Analog Line Level 5 8th June 2011 04:14 PM
Time domain interpolation instead of the usual low pass filtering? mr_push_pull Digital Source 13 30th March 2011 11:19 AM
Help with Subwoofer amp Low-Pass Filtering EWorkshop1708 Subwoofers 4 19th May 2009 05:51 PM
