Have the DIY Synergy speakers doing (almost) linear phase
Old 5th December 2012, 04:51 PM   #11
thirdman is offline thirdman  United States
Oh Yeah Baby! Now we are cooking. This sounds awesome Sergey. Which Akip Lab(http://www.akiplab.com/en/en_index.htm) ribbon are you using? Where did you get them and how much did they cost? Which Celestion drivers?
Would love to see how this build progresses.
This is Awesome!
Keep us up to date(you should start a thread)
FYI: BWaslo has built a Synergy with compression drivers and even recieved help on the crossover from Tom Danley.
ok, got a hold of myself now...got a little exited
thanks
Shane
Old 5th December 2012, 05:08 PM   #12
badman is offline badman  United States
badman's Avatar
I took a very similar approach with my latest crossover version, first order filters with lots of overlap and a second electrical pole kicking in closer to the final rolloff (with resistive damping on the woofer shunt capacitor).
It models a lot like your results above, and sounds superb.
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 5th December 2012, 05:38 PM   #13
Badman...you are a Bad Man.
That is a beautiful monster. I notice you have her on castors...hehe. What drivers did you use and what is in the throat of the wave guide?
Old 6th December 2012, 04:57 PM   #14
badman's Avatar
Thanks- the woofer is a BD BD15, one of the few 15"s one can trust to play a little higher (as needed for the relatively-linear-phase XO), and the compression driver is selenium d2500Ti. I modified the diaphragms with a homebrew coating of tacky glue (Foam glue, effectively the same thing as Aleene's Tacky glue, or several other white-glue products) and talc, diluted with water.
Made a big difference at the top end, commensurate with the smoothing one expects from damping. The very highest tizziness from phragm breakup seems to be gone, and a dip in the 6-8k region seems to have filled in, so it sounds more extended but less tizzy.
In the throat, is reticulated aquarium foam, a la geddes. I removed the bugscreens and smoothed the throat transition with clay, though I may do a silicone fill-in sometime, instead.
Old 6th December 2012, 07:12 PM   #15
puppet is offline puppet  United States
Gave up on the heil badman?
Old 6th December 2012, 07:15 PM   #16
badman's Avatar
Naw, but I decided to pull the active XO out of the rig for a while after I had something evil happen in my rig (think the switching pop from the pre set the crossover into some sort of malfunction mode, blowing the amp channel and associated woofer), and had been meaning to try the seleniums for a while, I'd previously run these OSWGs with JBL 2426h.
Old 6th December 2012, 07:43 PM   #17
tomtom is offline tomtom  Slovakia
Hi Badman
Very nice project. How low you cross WG?
Old 6th December 2012, 08:55 PM   #18
badman's Avatar
Xo is in the neighborhood of 1600Hz, but is first order down to about 1k, where a second electrical pole and a significant amount of acoustic rolloff begin, creating a very steep final filter function.
With the JBL 2426 this waveguide was very happy with a crossover more like 1kHz.
Old 6th December 2012, 08:57 PM   #19
ra7 is offline ra7  United States
Can you show us some measurements?
Old 6th December 2012, 09:29 PM   #20
badman's Avatar
I'll assume this is directed at me- and this is a good juncture for me to bow back out of the thread, certainly don't want to steal the OPs thunder.
I don't have measures I can share- my measurements are based upon in-room with use of an RTA/Mic, I do sweeps and whatnot but can't capture them. I simulate with PCD, and measure to ensure that there's nothing disagreeing with it.
Have the DIY Synergy speakers doing (almost) linear phaseHide this!Advertise here!
DIY Synergy horn paulspencer Multi-Way 53 5th December 2015 10:29 AM
DIY Unity/Synergy for home use nl Multi-Way 2 26th March 2012 08:56 AM
DIY Synergy horn ideas nl Multi-Way 8 3rd September 2009 04:42 AM
Pair Linear Phase Stereo Floor Speakers/Home Theater ! dale cooper Swap Meet 0 17th April 2005 02:54 AM
Pair Linear Phase Vintage Floor Speakers 10" Drivers !!! dale cooper Swap Meet 1 15th April 2005 05:52 AM
