Helmholtz Resonator Inside a Sealed Cabinet
What will be the result if inside a sealed enclosure we install a Helmholtz resonator tuned at the frequency of the system impedance peak? Most probably it has been long done, but Google and forum search didn't return an examined example of such system. Please, don't feel limited only to the matching fb's of both systems, the resonator could be tuned lower, higher or double tuned etc. Any experience, thoughts and analysis are welcome. Best regards!
Ikea Omni Bowl Speakers - New Project My Bulgarian Forum: http://penkiller.com/index.php |
#2 |
It puts a notch in the frequency response at the Helmholtz resonance frequency.
It actually works like a standard ported enclosure in that the Helmholtz resonance loads the driver, reducing its excursion, and thus reduces the radiation from the front of the driver. But in the standard ported enclosure the drop in driver output is compensated for by the output from the port. With a completely enclosed resonator you don't get the additional output, so the resultant output SPL curve is that of a sealed enclosure with a "notch" at the tuning frequency of the resonator. (More accurately, at the resonant frequency of the two coupled volumes, as they affect each other.) You might do this if you wanted to tame a driver resonance, but this is better done with an electrical notch filter ahead of the speaker. It is better to reduce the resonance exciting energy before it gets to the driver, rather than trying to damp it afterwards. Last edited by Don Hills; 17th September 2012 at 01:25 AM. |
#3 |
Thanks, I wasn't able to decide between loading and unloading.
The example that made me thinking is high Qts, low Fs bass driver. There is pretty good probability that the Akabak software is able to simulate such system, only that someone more knowledgeable than me must get interested and write the code. ![]() As for weighting the two alternatives, electrical and mechanical notch, maybe they are on par by cost or even with advantage in favor of the mechanical one. It is real itch to see an impedance curve modified with such a device. Best regards!
#4 |
If you figure out a way to reduce the cone resonance (about 2.5kHz) of many of the 8" Full Range light comne drivers with a simple set of "passive tuned notch resonators", you will have many happy people indeed, and maybe also customers.
There was some methods and technical evaluations done on this some years ago but I've never been able to find it either.
... jh |
#5 |
Sounds like allot tougher problem for a passive mechanical system.
With low frequencies and a resonator, there is no problem with the coupling and the magnitude as well. Coupling will occur irrespective of the resonator placement and magnitude will depend on pipe area. Further, there are designs with enclosed volume and pipe even TL ones. Only I have never seen tougher explanation of those. At 2.5 kHz with considerably shorter waves, the path is obviously with a notch filter. The same applies to paper cone sealed chassis tweeters, all have resonance between 1 and 2 kHz that leaves artifacts no matter how high and steep you cross them thus the necessity to always address the phenomenon. But here the topic is using a high Qts nicely voiced bass driver in a reasonably sized sealed enclosure. In any case they are not suitable for anything else and produce a nasty bump in the response and a big impedance peak. The same actually applies to any type of enclosure with such driver, not only sealed. Best regards.
Ikea Omni Bowl Speakers - New Project My Bulgarian Forum: http://penkiller.com/index.php Last edited by T101; 17th September 2012 at 05:39 AM. |
#6 |
the german diy magazine HobbyHifi discussed this issue a couple of years ago as a measure against standing wave artefacts in popular thin and high casings. Seemingly it worked well, at least measurement-wise. It´s kind of mechanical alternative for a electronic notch-filter. jauu Calvin
http://calvins-audio-page.jimdo.com |
#7 |
One bonus of using an acoustical filter is possibly better distortion performance. If a (distortion) harmonic of a fundamental hits the resonance peak and you only used notch in the electrical signal, it is not attenuated. The acoustical solution would notch out the distortion product also. Same principle as reducing distortion in low frequency bandpass and horn enclosures with their acoustic low pass function working at reducing all out-of-band content.
#8 | |
Look here, and also search DiyAudio: DCR |
#9 | |
Code:
Def_Driver 'Driver'
Sd=220.00cm2
Bl=7.00Tm
Cms=1.00E-03m/N
Rms=1.00Ns/m
fs=37.6374Hz |Mmd = 16.00g not recognised by AkAbak, fs calculated and used instead
Le=0.10mH
Re=7.50ohm
ExpoLe=1
| Sealed enclosure with an internal Helmholtz resonator tuned to the system's Fs.
System 'S1'
Driver 'D1' Def='Driver' Node=1=0=2=3
Enclosure 'E1' Node=2
Vb=77L Lb=25cm
Radiator 'Rad1' Def='D1' Node=3
Duct 'Du1' Node=2=4
dD=2cm Len=4cm
Enclosure 'E2' Node=4
Vb=10L Lb=10cm
#10 |
Thanks for that! If the effect of the resonator is the dip encircled in red on the simulation, then it works!
![]() This is very cool ![]() There are so many good sounding drivers with decently low Fs lacking the magnet power to be used in any enclosure. In vented it becomes even worse with high Qts drivers, but I can't simulate the added resonator in vented enclosure as well. Since I posted the thread, there is another suspicion in my head... What if the resonator is double tuned? I know, that there is no such thing as double tuned single enclosure. It is always a sum of the two vents acting as one with different proportions. But it could be possible to tune the resonator once to extract the bump out of the response of the high Qts driver and once more to the surroundig environment to aid the LF response. (DCAAV or DBR Fostex - the middle example from the link to DCR http://www.claudionegro.com/projects...r/dcr/dcr.html posted above) Another thought is application in enclosures for midrange drivers. Again there are allot of beautifully sounding fullrange and midrange drivers that produce a bump in sealed enclosures. Examples are some TB drivers with Qts around 0.7 as well as Visaton B200 if asked to serve as a midrange in 5-10L enclosure. Not to mention some internal cabinet reflections and resonances that occur at specific frequencies that can be cured with such resonator. The beauty of the method is that it is as easy to construct as double bottom and a pipe attached to it. We could improve the Akabak model in order to be usable by anyone. (or at least explain how to substitute the variables for different examples to ones like me :-) ) Link to the Akabak download page: Download - Akabak Best Regards! p.s. I'm excited
Ikea Omni Bowl Speakers - New Project My Bulgarian Forum: http://penkiller.com/index.php Last edited by T101; 18th September 2012 at 11:59 AM. |
| formula for Q of Helmholtz resonator | PeteMcK | Everything Else | 9 | 18th September 2012 02:12 PM |
| Soldering Inside A Cabinet | DreadPirate | Multi-Way | 6 | 5th December 2010 09:21 PM |
| Cabinet brace act as helmholtz resonator? | RyanW | Multi-Way | 17 | 2nd October 2007 11:08 PM |
| Dont want mr. Helmholtz in my sealed sub ! | Coolin | Subwoofers | 18 | 14th October 2005 09:13 PM |
