Hi all,
I want to use RS100-8 fullrange driver as mid in my next project crossed around 200Hz. I need to use it in a very small box ~ 0.3-0.4 litres. It will have bump around 200Hz with q around 1.5. I would equalize using linkwitz transform. Will there be a problem with a back wave escaping through the cone because of the small box being not big enough to contain enough stuffing? or any other reason why this is not a good idea? thanks martin |
#2 |
If also BR tuning is used for some mids , there must be a reason ...
200 Hz is a critical freq ( which it isn't ? ) and is the mid bass in full ,so it needs some breathe . I hope it's not a mid positioned in a paper tube as often seen in some old designs ; cylindrical is also the worst environment for a speaker ( in axis ). If you show the box .... !?! |
#3 |
not really sure what you are trying to say???
| Seas W17EX-002 smallest box volume and crossover freq | bacworth | Multi-Way | 22 | 30th May 2012 10:10 AM |
| Air Volume for Dayton RS100-8 4" Reference Full Range Driver | Leejin | Full Range | 14 | 24th May 2012 06:53 PM |
| FS: (4) Dayton RS100-4s + (1) Dayton RS100-8 | Fast1one | Swap Meet | 4 | 6th January 2010 10:32 AM |
