Measuring my speakers
Old 21st September 2012, 12:57 AM   #61
a.wayne is offline a.wayne  United States
Sin Bin
You guys do realize there's deadtime involved, when doing gated measurements it's not all text book out there...
Old 21st September 2012, 02:28 AM   #62
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
Are you talking about the time before time zero a.wayne?? I do vaugley remember that setting the gate further before time zero (zero padding??) could be used as a technique to get lower frequencies in your gated data, but It's not something that appears to work with holm... I think I used the technique in the past with speaker workshop, but abandoned it in preference of holm due to never being able to get consistent results with SW.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 21st September 2012, 05:44 PM   #63
JohnPM is offline JohnPM  United Kingdom
Originally Posted by sometimesuk View Post
if it takes 4.4ms for sound to travel five feet, assuming the microphone and speaker are both equal distance from the wall, then that gives you a window of at least 8ms to take a reading, as it would take the same time for the reflection sound to travel back to the microphone?
It depends how far apart the speaker and mic are. When trying to capture speaker response the mic is generally fairly close, in which case using the distance to the nearest surface is conservative. If they are further apart, the window could need to be even narrower - for example, if the nearest surface was 5 feet away but the mic and speaker were 10 feet apart, the shortest path that includes the surface would only be 4 feet longer than the path taken by the direct sound and would arrive 3.7 ms after it. In practice the window can usually be set by looking at the impulse response to identify the earliest significant reflection.
Old 6th October 2012, 10:54 PM   #64
lduarte1973 is offline lduarte1973  Portugal
Banned
my latest in room mesurement , after a lot of messing with eq and xover this sounds best to me
Old 7th October 2012, 11:31 AM   #65
jerome69 is offline jerome69  France
jerome69's Avatar
You like bass and treble tiz-boom ?
Old 7th October 2012, 12:47 PM   #66
Sin Bin
Attachment 305049
Can you post pics of your speaker , by recessing the middle you may be trying to hide some kind of obvious ringing taking place in your midrange driver , due to
1. Driver
2. Poor design of xovers
3. Cabinet design ...
4. All of the above
Can you also post a pic of the impedance magnitude and phase ..?
Old 8th October 2012, 07:27 AM   #67
Banned
im forbidden by my wife to make any room treatment and without it the room is very reverberant to mid frequencies.The cabinets are from JBL LX400 , and have a ressonance around 1.2k because the baffle is too narrow.
Old 8th October 2012, 08:24 AM   #68
Banned
i listen mainly to rock music so i need some bass boost and i like a litle treble boost also , but i still need to take care of that peak near 20k
Old 8th October 2012, 08:26 AM   #69
Banned
ill post it in the evening
Old 8th October 2012, 08:14 PM   #70
Banned
Impedance magnitude and phase
speakers :
7" woofer ; 5" mid ; 1" tweeter
Measuring my speakersHide this!Advertise here!
Help in measuring speakers ARIYAHOOR Multi-Way 34 17th October 2012 06:38 PM
Measuring Ported Speakers ilardi Multi-Way 15 25th February 2012 09:14 PM
Question on measuring speakers gedlee Multi-Way 16 15th November 2011 11:13 PM
Measuring a speakers efficiency pjpoes Multi-Way 14 30th January 2009 03:35 PM
Need some guidance on measuring speakers mazeroth Multi-Way 4 25th January 2006 05:19 PM
