Measuring my speakers
Old 18th September 2012, 10:31 PM   #41
Pano is offline Pano  United States
Pano's Avatar
TVR. Yes, mid-size room, fairly dead. But I get identical results measuring amps and pre-amps, too. Maybe they would not show the difference?
Old 19th September 2012, 12:21 AM   #42
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
Originally Posted by tvrgeek View Post
You have a big dead room? At 1/3 octave smoothing, or nearfield, they are close. At 1M, 1/24 the differences are large. Below about 200 Hz, I use sweep.
Are you sure it is noise, not diffraction, reflection, basket reflections and other nasties?
measuring distance about 1.2M Similar distance to floor and ceiling. The comment about using sweeps below 200Hz tends to fit with what I recall that I could gate lower with the swept sines. I hypothesized that it was actually late reflections of the MLS signal that were messing things up, and that the swept sines weren't as susceptable (exactly the opposite to what I had read).
I just loaded some old measurements (about 2.5 years ago). I could only find one direct swept sine vs mls measurement and it is very close to identical. So maybe my memory is faulty... blue is MLS red is Swept Sine. Only details I have is that the measurement was taken at 1.5M.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 19th September 2012, 08:50 PM   #43
lduarte1973 is offline lduarte1973  Portugal
Banned
my latest mesurement , not exactly flat but the best sounding to my ears , i managed to get a almost perfect flat curve but sounded like
Old 19th September 2012, 10:05 PM   #44
Banned
slightly different version of xover : woofer & mid 18db 800/4k
Old 19th September 2012, 11:02 PM   #45
tvrgeek is offline tvrgeek  United States
I would really hope an op amp or preamp electrical measurement is not influenced by reflections and refraction from the room. I have not had time to play with MLS for electronic testing. I usually just use my old trusty TrueRTA and spreadsheet for calculating harmonic distortion.
Old 19th September 2012, 11:03 PM   #46
Ah yes, Grasshopper, you have reached a major step in your path to enlightenment.
Old 19th September 2012, 11:06 PM   #47
Attachment 302197
Not knowing the details, I might think your BSC is coming in a bit early. Maybe crossovers not positioned quite right. Have you measured the system with each driver independently so you can separate the driver/crossover issues from driver/room issues?
Old 19th September 2012, 11:41 PM   #48
Banned
i havent mesured the drivers , im using the xover points at 800 and 4k they where used in the original (JBL) xover , i tryed several xover points and these sound best to me. do you suggest others ?
what do you suggest in therms of BSC ?
Old 20th September 2012, 06:33 AM   #49
sba is offline sba
REW is a great program. I tested it side by side with HOLMimpulse and got nearly identical results.
Here's a brief and good introduction to measuring speakers--
cpyrighted material removed
Sorry for the poor quality images!
Last edited by wintermute; 20th September 2012 at 11:16 AM. Reason: remove copyrighted material.
Old 20th September 2012, 11:17 AM   #50
just another
wintermute's Avatar
sorry sba I had to remove the attached article scans, as they appear to be copyrighted material.
Tony.
Some of my photos
Measuring my speakersHide this!Advertise here!
Help in measuring speakers ARIYAHOOR Multi-Way 34 17th October 2012 07:38 PM
Measuring Ported Speakers ilardi Multi-Way 15 25th February 2012 10:14 PM
Question on measuring speakers gedlee Multi-Way 16 16th November 2011 12:13 AM
Measuring a speakers efficiency pjpoes Multi-Way 14 30th January 2009 04:35 PM
Need some guidance on measuring speakers mazeroth Multi-Way 4 25th January 2006 06:19 PM
