Measuring my speakers
Old 17th September 2012, 10:23 AM   #31
tvrgeek is offline tvrgeek  United States
You wouldn't earn to swim if you did not know there was deep water.
Old 17th September 2012, 11:52 AM   #32
DavidL is offline DavidL  United States
Banned
I also have the 4 volume anthology Loudspeakers published by the AES. f you think Joe D-Apolitto's book is difficult, then try reading through that, although I have learned a lot from those too. Nothing doing well comes easily but takes lots of study and dedication. I think suggesting to a beginner Joe D-Apolitto's book is the right thing to do just to show them what they don't know yet, but if they apply themselves to learning, then it will be worthwhile.
Old 17th September 2012, 12:54 PM   #33
Barleywater is offline Barleywater  United States
Originally Posted by tvrgeek View Post
You really need to change to MLS type measurements. Sweep is great for below 200, but above that, to separate the room from the speaker, you need a gated pulse.
Great results are possible with both MLS and sweep methods. Both are capable of measurement from virtually DC to Nyquist. However: MLS is more sensitive to noise in environment. Swept sine has better S/N than MLS. MLS brings out worst in slewing behavior of drivers and electronics. And: REW has perfectly useful gating features too.
Old 17th September 2012, 01:56 PM   #34
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
yes I used to solely use MLS signals but decided to try swept sine (so I could get distortion measurements) and actually found that I got better measurements with swept sine than with MLS. This was using holm impulse.
Pink noise measurements in REW (using the RTA) are good at the listening position as well, especially if you play around with the averaging. see this post by Markus for some ideas http://www.diyaudio.com/forums/multi...ml#post2737602
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 17th September 2012 at 02:09 PM. Reason: add link to markus' post on pink noise with REW RTA
Old 17th September 2012, 09:46 PM   #35
If you are not using a gated measurement, you are measuring speakers in a room. To measure speakers, use the gated measurements.
When you say "better" does that mean smoother, prettier, or closer to what you think you hear?
Old 18th September 2012, 01:26 AM   #36
Pano is offline Pano  United States
Pano's Avatar
Strange, because I seem to get identical results. Wonder what the difference is?
Old 18th September 2012, 05:20 AM   #37
just another
wintermute's Avatar
From memory I found (at least where I was measuring) that I got less noise with the swept sine compared to MLS. I think that they both gave the same FR but I think that I could move the gating lower with the swept sine than I could with the MLS without the higher frequencies looking like they needed a shave I'll have to be a bit more scientific the next time I'm doing some measurements.
Tony.
Some of my photos
Old 18th September 2012, 01:11 PM   #38
Pano's Avatar
Yeah, let me know what you find. I'll look at it too.
Old 18th September 2012, 08:53 PM   #39
You have a big dead room? At 1/3 octave smoothing, or nearfield, they are close. At 1M, 1/24 the differences are large. Below about 200 Hz, I use sweep.
Old 18th September 2012, 08:54 PM   #40
Tony.
Are you sure it is noise, not diffraction, reflection, basket reflections and other nasties?
Measuring my speakersHide this!Advertise here!
Help in measuring speakers ARIYAHOOR Multi-Way 34 17th October 2012 07:38 PM
Measuring Ported Speakers ilardi Multi-Way 15 25th February 2012 10:14 PM
Question on measuring speakers gedlee Multi-Way 16 16th November 2011 12:13 AM
Measuring a speakers efficiency pjpoes Multi-Way 14 30th January 2009 04:35 PM
Need some guidance on measuring speakers mazeroth Multi-Way 4 25th January 2006 06:19 PM
