Measuring my speakers - Page 6 - diyAudio
Old 20th September 2012, 12:32 PM   #51
Stupid question, but whats wrong with mesuring in the listening room, if thats where the speaker is going to be used?
Old 20th September 2012, 01:35 PM   #52
just another
wintermute's Avatar
There's nothing wrong with it per se, but for designing the crossover itself the usual thing to do is measure the drivers individually (with gating for most of us without access to an anechoic chamber) and design the crossover based on those measurements.
In room measurements of the drivers without gating will include all sorts of room effects that you might try to correct for in the crossover if you were to try to design with those. what's more slight changes in the positioning of the speakers (from where they were for the original in room measurements) could change the measured response significantly (meaning that those corrections may now be completely wrong for the new position).
Much better IMO to design the crossover with semi anechoic data, allowing phase matching of the drivers etc, and then worry about whether or not to do anything about the peaks and troughs the room introduces once you have the speaker sorted.
I personally have done nothing more than play with the positioning of my speakers when it comes to in room response, and to me it sounds ok. Objectively it doesn't measure too bad either (apart from two big spikes, one at 40Hz and another around 550Hz).
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 20th September 2012 at 01:38 PM. Reason: expand a little.
Old 20th September 2012, 06:12 PM   #53
Another silly question, what is gating? hanging the drivers in the air?
Old 20th September 2012, 07:59 PM   #54
Pano is offline Pano  United States
Pano's Avatar
Gating is done electronically in the measurement program. Basically, it discards all sounds that arrive after a certain time, usually measured in milliseconds. The "Gate" closes.
Old 20th September 2012, 08:53 PM   #55
JohnPM is offline JohnPM  United Kingdom
Originally Posted by Barleywater View Post
Swept sine has better S/N than MLS.
Originally Posted by tvrgeek View Post
If you are not using a gated measurement, you are measuring speakers in a room. To measure speakers, use the gated measurements.
When you say "better" does that mean smoother, prettier, or closer to what you think you hear?
"Better S/N" means exactly what it says, better signal to noise ratio in the impulse response derived from the measurement. All MLS and sweep measurements apply 'gating' in the process of generating the displayed frequency response from the impulse response, i.e. the impulse response is multiplied by a window function to select the desired portion before calculating and displaying the frequency content of that selected portion. Using narrower gates/shorter time windows allows contributions after the direct sound that arrive outside the window to be removed, but the width of the window also determines the lowest frequency that can be determined. For example, if the speaker and the mic were each at least 5 feet from the nearest surface (floor, wall, ceiling, furniture) a window of 4.4 ms could be applied, as sound takes 4.4 ms to travel 5 feet. The resulting frequency response would then exclude any contribution other than the direct sound from the speaker, but the lowest valid frequency in the response would be 225 Hz (1/0.0044).
Old 20th September 2012, 09:14 PM   #56
tvrgeek is offline tvrgeek  United States
Sorry if it is not as pretty, reality is not pretty. If you want to make it pretty, use the averaging function. Don't be fooled by the averaging functions though; they differ product to product.
I think the term "signal to noise" is a very poor choice here. "Signal to spurious signal" may be a better description. Noise implies a unwanted signal riding on the desired signal. Reduction of the spurious signal is exactly what MLS does a sweep can not. Think about the MLS signal. What it really is is the sweep all at once.
Old 20th September 2012, 09:19 PM   #57
Like Winter said, you need to measure the speaker to design the box and crossover. This is where manufactures have to stop. ( or they guess about your room, usually not very well) DIY has the advantage of putting the speaker system in the place where it will be used for final voicing.
When you do start measuring in-room and at listening position, really quick you will learn you do not want a perfectly flat response. You want to let your brain do the weighting based on the basic acoustics of the room. If you try and fool it, it gets unhappy. Your brain makes a memory as soon as you walk into a room just from ambient sounds.
Old 20th September 2012, 09:20 PM   #58
a.wayne is offline a.wayne  United States
Sin Bin
I'm not a fan of smoothing , tends to hide smearing , due to poorly designed drivers, xover and or cabinet, thus killing inner details.
Old 20th September 2012, 09:27 PM   #59
That statement is simply incorrect. If you would like to understand how acoustic measurement methods work, including MLS and sweeps, this paper provides a good overview.
Old 20th September 2012, 10:35 PM   #60
if it takes 4.4ms for sound to travel five feet, assuming the microphone and speaker are both equal distance from the wall, then that gives you a window of at least 8ms to take a reading, as it would take the same time for the reflection sound to travel back to the microphone?
Help in measuring speakers ARIYAHOOR Multi-Way 34 17th October 2012 06:38 PM
Measuring Ported Speakers ilardi Multi-Way 15 25th February 2012 09:14 PM
Question on measuring speakers gedlee Multi-Way 16 15th November 2011 11:13 PM
Measuring a speakers efficiency pjpoes Multi-Way 14 30th January 2009 03:35 PM
Need some guidance on measuring speakers mazeroth Multi-Way 4 25th January 2006 05:19 PM
Copyright ©1999-2017 diyAudio
