Controlled vs wide dispersion in a normal living room environment.. Controlled vs wide dispersion in a normal living room environment.. - Page 41 - diyAudio
Old 24th September 2012, 03:23 PM   #401
graaf is offline graaf  Poland
graaf's Avatar
Originally Posted by gedlee View Post
I have yet to see a good presentation of the CBT frequency response, ala a polar map, to see how well they actually do what's claimed. Don's discussion is theoretical not real data. Shaded curved line arrays are far from new, why all-of-a-sudden are they of such interest?
exactly, and one can use the old ArraySHOW simulation program by Mark Ureda to get an idea of what happens to vertical and horizontal directivity in such a convex Legendre shaded array, certainly this is not a Holy Grail of a domestic loudspeaker
It is good to know Omholt's agenda now one knows who's talking
Old 24th September 2012, 04:05 PM   #402
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
The question I would ask, as I have in similar threads, is this:
What level of 'controlled directivity'?
I would say that vertically the pattern should be narrower than horizontal, but how much? 60'x120'? 60'x90'? Since we're talking 'controlled', then CD is obviously included.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 24th September 2012, 04:17 PM   #403
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by a_tewinkel View Post
All things considered, I think a well engineered waveguide speaker will perform better with minimal treatment when space is an issue. If you have lots of space around the speaker, a CBT may be a better choice.
I am mostly with you here, except that as the room gets larger then other factors of the waveguide, like efficiency and power handling, come into play creating a preference for the waveguide, IMO. I know the CBT is claimed to have good power handling, but that is certainly an area where I have my doubts. We are still talking about very small speakers handling very wide bandwidths. Numbers help, but not all that much.
We don't talk much about the vastly superior sensitivity and power handling of a compression driver waveguide because in a small room its not really a big factor. But as the room gets bigger this fact is undeniable and the reason why ALL large venue playback systems are horns.
Earl Geddes Gedlee Website
Old 24th September 2012, 04:24 PM   #404
gedlee's Avatar
Horizontal should be below 90 - this allows toe-in that keeps the speaker from illuminating the nearest walls. In the verticle, narrower is desirable, but at what cost? If compromises of the horizontal need to be made to achive a narrower vertical then I am still of the opinion that this is a bad tradeoff. Better to handle the floor and ceiling with room treatments, but leave the side walls reflective. Verticle reflections do not add to spaciousness, in fact there are no positives for them. Reflective side walls, fairly absorptive ceiling and floor - the ideal situation for an axisymmetric waveguide and one easily achieved in practice.
Old 24th September 2012, 04:36 PM   #405
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
I think that you need to look at each implementation specifically verses generic answers to the questions here. There are many different designs in each category and each implementation has its own effects. While we have what are called CD waveguides I would say that many so called CD waveguides are anything but. As Gedlee will say himself many of the so called CD conic waveguides are anything but in reality. The same thing goes for vertical line-array's, what we are really talking about here. Line arrays have very specific comb filter effects that have been well known for decades. though the tiny devices and minimal center to center distances for all the devices we are looking at in these home systems would limit some of the problems with lobbing like a professional PA system will have to deal with. But think of the string of devices in these line arrays. Nobody is going to produce very high impedance devices for these line arrays, the speakers are standard devices strung together and this isn't being talked about. Think about the impedance curve when you connect devices in series-parallel and one device is seeing the voice=coil inductance's of one or two or three other devices in a series, not a great idea in my mind. This tells me that the individual devices are not at all equal across the line, we have a shifting frequency response up and down the array if I am correct. And Gedlee is correct that the polar plot shown earlier is only a theoretical drawing, not a real resultant. Lets see a real polar plot of a real line array such as discussed here for a home. I am not advocating for either type of device just saying that each has its place and each has its own limitations when looked at in the real world and not the theoretical realm.
Old 24th September 2012, 04:37 PM   #406
Thanks Gedlee. That answered it perfectly, and it agrees with my thoughts. Even though i was 'stabbing in the dark'. I am using a waveguide loaded ribbon, and id estimate a 60x120 pattern, perhaps 60x90, its hard to say by merely looking. I found the control of vertical radiation a large improvement over the domes im used to. Having said that, Ive also had some success with felt around the tweeter, and foam in the throat of the waveguide. Unfortunately, i dont have room for 'real' speakers of the kind that youre known for, and like many I still hope to control radiation pattern to some degree.
Old 24th September 2012, 04:56 PM   #407
Tom Danley is offline Tom Danley  United States
Location: Sitting behind the 'puter screen, in Illinois, USA, planet earth
Hi
An alternative is even more directivity
To the degree one can place two loudspeakers side by side in a wider angled “array” and not hear anything funny as you walk back and forth, one can possibly place that speaker on a boundary and not produce an audible reflection.
In installed sound, contractors often install our Synergy horns that way although is usually on the ceiling but I have done this for stereo on side walls. .
That works very well because you can place two SH-50’s, sm-60’s etc hard packed (the side walls of the cabinet are equal to the horn wall angle and only a few inches away) tight packed and you cannot hear a seam or any artifact walking back and forth.
As they each radiate a “pie slice” over a broad band from a point at the very rear of the cabinets and have pattern control to a “lowish” frequency , they couple into one wider source well enough to have an inaudible seam. One can substitute a physical boundary to produce a mirror image of the second source.
The “CLF” data format we have the loudspeakers in has things like polar plots and a 3d view of the radiation.
For an SH-50, even aimed normally (right speaker at left most seat and vis versa) they radiate less than normal to the sides and rear, for example 90 degrees off axis at 500Hz they are still nearly -20dB down H and V and at 250Hz about -7 or 8 dB down 90 off axis.
There are NO crossover or multi-source lobes or nulls to worry about, the result of the linear phase crossover is they really act like there is only one driver in time to the degree they reproduce a square wave over more than a decade wide band and in space, that you can walk up, stick your head into the horn mouth and never hear anything other than one source floating in front of you.
With pattern control that low, it is easy to place the speaker a fraction of a wl from the boundary with the -6dB radiation angle parallel to the room wall / boundary and viola, effectively no wall reflection.
Vertical reflections are usually unavoidable but with the horn at half room height, there is a reflection free zone that extends to just short of twice the distance from the vertical pattern angles and ceiling and floor intersection.
In other words, if the floor and ceiling were mirrored, you would want to be seated closer than the distance where you can see the Horns compression driver in the mirrors.
At that much closer distance, much less of the reflected energy will reach you.
The side wall approach takes care of that acoustic image from the close wall and the same mirror idea would apply to the reflection from the opposite wall. While these aren’t made for hifi they certainly work for that.
On the CBT, I will be seeing Don Friday at an AES /ASA meeting we are both presenting at so maybe I can pick up more info about how they measure.
I haven’t been active in either AES or ASA for a while but it will be fun showing Don these horns as a number of the aspects he discovered / described apply to these.
Best,
Tom Danley
Danley Sound Labs
Bring back mst3k and futurama
Old 24th September 2012, 06:17 PM   #408
Omholt is offline Omholt  Norway
Omholt's Avatar
So no bias here for your "new" speakers.
Strange comment. I didn't think you cared too much about looks of a speaker? I'm not here to defend anything and have no agenda, but simply sharing my personal view on the estetiques. I have waveguide speakers as well, and I enjoy both.
I'm probably also the only one here who have seen several CBT speakers with different finishes.
Here's pics of your speaker and a CBT and then people can decide for themselves.
It's out there in the public. Don has published a lot and more is coming.
The CBT tehnology is quite new and they solve a lot of issues. It has the strength of a regular line array, but not it's weaknesses which some are mistakenly thinking.
A more uniform polar response and a more even frequency response is something I at least welcome.
a_tewinkel:
I have like previously mentioned not seen any high gain reflections arriving of the frontwall from the CBTs. I've measured, and I will do it again when I get back my crossover unit.
I believe many are making wrong judgements based on assumptions and misunderstanding the concept.
CBT36 can handle much power and play extremely loud. They do need subs for the lowest frequencies, rolling off at about 45Hz, but there's also bigger CBTs that have deeper bass. The CBTs are very flat and even down to about 100 Hz. Beat that!
Old 24th September 2012, 06:23 PM   #409
SEdwards is offline SEdwards
Hi Tom,
If you have time, I'd love it if you could comment on the feasibility of a unity horn experiment that I am planning. This goes back to post from a few pages back about using the floor to extend the horn/create mirror sources. (i.e. cutting a horn in half and using the floor to close it). I watch my projector from the floor.
This problem here would be maintaining enough symmetry for the treble to be well behaved. My plan is to make a ribbon or planar magnetic tweeter to feed the throat. This could be small and easily made flush with the horn. A square format would be easy to mate with a square throat, too. I expect that at my low SPL requirements (average 80 dB at 1 m) I should be ok with all the horn gain available.
Is this a reasonable plan for a low SPL speaker with good directivity?
Old 24th September 2012, 06:38 PM   #410
a_tewinkel is offline a_tewinkel  Netherlands
a_tewinkel:
My comment on the front wall was not specifically on the CBT, but front wall reflections (even at moderate levels) have been found to cause colouration with other box speakers. They may be difficult to measure in the presence of multiple other reflections. However, I think it is safe to assume that the CBT, being a narrow closed baffle speaker, will have the same potential problem. Depends on the distance to the wall of course.
I have been very interested in the CBT technology and have studied it thoroughly. It is a very well engineered loudspeaker with some very desirable characteristics, most notably the vertical radiation pattern and interfacing with the floor. The CBT36 has sufficient power handling and volume displacement to be coupled with a subwoofer and play at high levels.
However, personally I think a good waveguide loudspeaker has a slight advantage in small rooms. I think that the image will be better defined and that it will be less sensitive to placement near walls. It is more sensitive to the floor reflection, but as I mentioned, that can be easily dealt with.
Controlled vs wide dispersion in a normal living room environment..Hide this!Advertise here!
Ultra-wide dispersion drivers? nonsuchpro Multi-Way 30 27th August 2012 11:41 PM
Best horn for 1" throat HF driver with wide dispersion and flat responce? cka3o4nuk Multi-Way 4 13th May 2012 02:30 AM
Wide dispersion speakers using full (wide) range drivers ozziozzi Full Range 1 28th December 2008 06:13 AM
An idea for a wide dispersion ESL jerko Planars & Exotics 25 29th November 2007 02:16 PM
Sub placement to counter wide dispersion? kyrie48 Subwoofers 3 20th September 2007 04:33 AM
Copyright ©1999-2017 diyAudio
