Listening seat against rear-wall - How bad is it? How to reduce inherent problems?
Old 12th November 2012, 10:36 AM   #21
markus76 is offline markus76  Germany
Banned
Originally Posted by Elias View Post
There was an article by Joachim Gerhard stating the optimum listening position was against the real wall. Speakers were placed far from walls.
Do you have a link?
Old 12th November 2012, 10:57 AM   #22
Elias is offline Elias  Finland
Elias's Avatar
His proposal looks like this. Listening position at the wall, and speakers almost in the middle of room.
Practical or not, that was considered optimal.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 12th November 2012, 10:58 AM   #23
Banned
"Optimal" in terms of what?
I'd think having on-wall or better in-wall speakers with the seat away from the wall is much better in terms of clarity and spaciousness.
Old 12th November 2012, 03:39 PM   #24
Soundtrackmixer is offline Soundtrackmixer  United States
I have to agree with you Markus.
Old 12th November 2012, 03:43 PM   #25
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Do you have a link?
http://www.essex.ac.uk/csee/research...0placement.pdf
The pictures in above paper say that ears should be 0.4-1 m in front of wall. So much for "seeing is believing" .
Rudolf
www.dipolplus.de
Old 12th November 2012, 03:46 PM   #26
a_tewinkel is offline a_tewinkel  Netherlands
I also agree. For practical reasons I have my seat against the rear wall. Because there is audible colouration from the rear wall reflection, I put an absorber against the wall. This helps for timbre but unfortunately it really kills spaciousness and makes the sound somewhat dry/less lively.
Old 12th November 2012, 03:57 PM   #27
breez is offline breez  Finland
a_tewinkel:
How are the side walls? I have the thick absorber behind my head, but I feel quite strong spatial effect with bare side walls. Speakers on the long wall with strong toe-in. Speakers have smooth, but wide dispersion (Seas DXT + 6" woofer).
Old 12th November 2012, 03:57 PM   #28
Banned
Originally Posted by Rudolf View Post
Old 12th November 2012, 05:17 PM   #29
Originally Posted by breez View Post
a_tewinkel:
Side walls are at least 2 metres away from the speakers and the have a +-60 degree coverage angle, so that contributes to the lack of spaciousness. But the change in 'dryness' with the absorbers is profound, it may be less so with closer side walls or wider dispersion.
This set-up is not optimal for these speakers, they would do pretty good relatively close to the side walls. But in my room that is not an option.
Old 13th November 2012, 07:14 AM   #30
Banned
Just to put the record straight, this is what was recommended - note the minimum distance from the back wall:
Listening seat against rear-wall - How bad is it? How to reduce inherent problems?Hide this!Advertise here!
Rear port close to wall dilema Aleph 5 Multi-Way 24 12th August 2011 06:57 PM
speakers near the rear wall sprinter Multi-Way 5 28th February 2011 02:28 AM
How to remove rear seat and plastic??? BlacknRedGT Construction Tips 2 24th April 2009 12:38 AM
Any inherent problems with this enclosure design? Lothar34 Subwoofers 21 4th October 2006 10:32 PM
