Listening seat against rear-wall - How bad is it? How to reduce inherent problems? - Page 2 - diyAudio
Old 14th September 2012, 06:30 AM   #11
Banned
Originally Posted by keyser View Post
I do experience an effect in the low midrange I don't know how other to describe than 'phasyness'.
That's probably a low(er) frequency room effect. Run a slow sweep. Do you get a lot of fluctuating directional sensations?
Old 19th October 2012, 09:28 PM   #12
Since a couple of weeks I've got a big damping panel behind me, measuring 2m40 by 1m20 and 20 cm thick. I wish I could've made it even thicker, but this is as far as the girlfriend allowed me to go .
Measurements indicate that above about 500 hz it works almost as a black hole
What panel did you use?
How you perform the measurements?
Old 19th October 2012, 09:39 PM   #13
kevinahcc20's Avatar
In most rooms you don't need or want the sofa right tight to the rear wall...if you move it out just 16" that will put your ears 2' from the wall with much improved sound and better WAF.
Kevin(ahcc20)...I'd rather have a bottle in front of me than a frontal lobotomy!
Old 20th October 2012, 06:01 PM   #14
Pano is offline Pano  United States
Pano's Avatar
Yes! How did you measure that? I'd like to try it.
FWIW, my sofa is about 2 feet (60 cm) from the rear wall. I have panels on the wall that are 6" (15 cm) thick on that wall. They seem to work well, tho I do need some more coverage.
Great topic.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 20th October 2012, 11:42 PM   #15
chris661's Avatar
This is also my current listening situation.
Treating the room isn't an option (uni dorm room), so I tend to sit on my bed, leaning back on a pillow to listen to music. More comfortable than leaning on the wall, and the sound's better.
I do still have a strong resonance in the ~120Hz range - I suspect it's a standing wave as the wavelength seems to coincide with the room width.
I can lean forward and the resonance dies down somewhat, but the room is also very lossy in the bass - crank it up so you can feel it in one place, and in other places you'll think you're listening to 3" satellite speakers with no sub.
Hopefully a dedicated subwoofer will sort this out, and provide some more <40Hz oomph for parties too.
Chris
Old 21st October 2012, 07:49 AM   #16
keyser is online now keyser  Netherlands
keyser's Avatar
I'll try that and let you know.
I used the fiber glass batts that were available at the local hardware store. The measurements were not directly on the panel itself. I just compared several measurements at and around the listening position before and after installing the panel. There are very obvious differences above 500 hz. At lower frequencies the effects are simply less significant.
Perhaps not, but in our room this is really the most convenient way to set up the listening triangle. I know many others with the same kind of setup.
Dutch & Dutch
Old 21st October 2012, 07:31 PM   #17
A little bit of topic, but be aware that inhaling glass fibers could cause you lung problems, so i suggest you to use absorbers based on synthetic materials instead which are 100% safe.
Old 12th November 2012, 08:08 AM   #18
keyser's Avatar
Sorry about not getting back to you sooner - but you were right! There was some interference going on in the 100 to 150 hz range. That's fixed now. I'm running a pair of Keele CBT-like speakers and I've dropped the crossover to the subs to about 90 hz.
Dutch & Dutch
Old 12th November 2012, 08:15 AM   #19
mondogenerator's Avatar
Thats great! There is hope for those of us living in distinctly non-palatial Euro-boxes after all!
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 12th November 2012, 10:27 AM   #20
Elias is offline Elias  Finland
Elias's Avatar
There was an article by Joachim Gerhard stating the optimum listening position was against the real wall. Speakers were placed far from walls.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Rear port close to wall dilema Aleph 5 Multi-Way 24 12th August 2011 06:57 PM
speakers near the rear wall sprinter Multi-Way 5 28th February 2011 02:28 AM
How to remove rear seat and plastic??? BlacknRedGT Construction Tips 2 24th April 2009 12:38 AM
Any inherent problems with this enclosure design? Lothar34 Subwoofers 21 4th October 2006 10:32 PM
Copyright 1999-2017 diyAudio
