Old 12th September 2012, 10:42 PM   #1
juanito is offline juanito  Europe
juanito's Avatar
Question Any ideas for a 2 way with SS 12M/4631G05?
Hi, does any body know any design useing this mid drivers, in a small 2 way system? Something like the mini ekkles from troels gravesen web site.
Old 13th September 2012, 01:38 PM   #2
Jonasz is offline Jonasz  Sweden
Jonasz's Avatar
I believe these are made to be mids in a 3-way, at least that's how I would use them. If you want a 2-way look at any of the SS 15W drivers instead.
Old 14th September 2012, 09:11 AM   #3
As above but for a two way I would be looking to use the 18W. Just playing with some 12MU’s myself now using an active crossover, IMO the 12’s would be a bit thin below 1kHz.
Old 14th September 2012, 02:01 PM   #4
juanito's Avatar
I thoght there was some equivalent to ekkels with the Seas w12oo3.
Thanks for the help.
I allready have SS 18w in a 2 way, I wanted something compact, very compact.
Cheers
Old 15th September 2012, 05:56 AM   #5
Ok well if you want compact size them that means compromising on the bottom end... but consider the cost of the Revelator in question I would be more inclined to use the 4ohm Illuminator.
Old 15th September 2012, 09:53 AM   #6
juanito's Avatar
Thanks silent screamer, I can get the revelators very easy, thats why I consider these. Still is just if there is such design. I don't have any skills for design... I can play arround with kit o rproject, but not more.
Old 15th September 2012, 11:41 AM   #7
A two way is probably one of the less complicated ways to go, what sort of tweeter did you have in mind? That would make a big difference as to where you should crossover and what mid to use.
Old 15th September 2012, 03:35 PM   #8
juanito's Avatar
What do you suggest?
Old 16th September 2012, 01:39 AM   #9
If I was wanting to put together a very small two way that would provide max music for min size, it would probably look at a SS 2904 or 3004 tweeter with the 12MU4731 to have both tweeter and mid 4ohm for passive integration.
I would put them in a sealed box as small as the speakers would allow (~1 litre ideal but would be closer to 2) and use heavy stuffing.
pop yourself a little sub somewhere not visible and you have the makings a fairly decent compact sound.
Old 16th September 2012, 02:39 AM   #10
Just looking at the 12MU sealed driver specs...
What you need to bare in mind is that the driver has a diameter of 120mm so the baffle face needs to be at the very least 120mm wide by 120mm high and as you probably know 100mm x 100mm x 100mm is a litre, so all efforts need to be done to keep the size down to a min.
Not factoring in inside and out figures dimensions there, but you get the point. It is hard to get these small drivers in a sealed enclosure that works well.
I have knocked together a couple of variations you might want to consider. I was playing with making an sealed enclosure for two 12MUs and just modified it.
If you wanted ultra small you could put the tweeter on the end and have the mid facing up but I wouldn't go that way.
I'm looking for Sony midrange pair (from high-end ss-g7 / ss-g9) vintnt Swap Meet 2 22nd April 2011 09:23 AM
I need a simple ss reverb for a ss guitar amp. yeto Instruments and Amps 8 18th January 2006 06:54 AM
SS R2904/7000 ring vs SS D2904/71000 dome opinions?? Adam D Multi-Way 0 1st September 2004 10:39 PM
12m/4631g00 sma Multi-Way 0 7th May 2004 09:33 AM
Help...I need a crossover for SS 18W/8545 and SS D2905/9300 softman Multi-Way 8 19th November 2002 07:11 PM
Copyright ©1999-2013 diyAudio
