loudspeaker enclosure design - Page 4 - diyAudio
Old 10th October 2012, 04:24 PM   #31
Dissi is offline Dissi  Switzerland
I hope davidel94 is only occupied to measure the Qts of his woofers. It was only an assumption, the driver will have a Qts around 1, as cheap drivers often have. Let's wait on the results.
Another method to find out Qts is to use LIMP:
ARTA Home
Old 24th October 2012, 02:14 PM   #32
hi sorry if i disappeared but i had some school's exams, i will do the Qts test the 1st or 2nd of november
Old 30th October 2012, 12:57 AM   #33
The review of the tweeter Monacor HT22/8 is now online:
Test Lautsprecherchassis Hochtöner - Monacor HT22/8 -
Old 30th October 2012, 01:20 AM   #34
Originally Posted by sreten View Post
In this case active bi-amping is a waste of time and money.
The passive filter functions you need are nothing like the
active filter functions provided by "off the shelf" x/o's.
The tweeter is most probably designed to have a single
series capacitor giving you a 3rd order acoustic roll-off.
(True for nearly all cheap (high Fs) tweeters.)
You just put this in parallel with the bass/ mid. The simple
treble x/o usually means the skill is getting the bass/mid
to match with proper BSC and complementary x/o point.
rgds, sreten.
http://sites.google.com/site/undefinition/diy
(see if nothing else, the excellent FAQs)
The Speaker Building Bible
Zaph|Audio
Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter
http://audio.claub.net/Simple%20Loud...ign%20ver2.pdf
FRD Consortium tools guide
Designing Crossovers with Software Only
RJB Audio Projects
Jay's DIY Loudspeaker Projects
Speaker Design Works
HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs.
A Speaker project
DIY Loudspeaker Projects Troels Gravesen
Humble Homemade Hifi
Quarter Wavelength Loudspeaker Design
The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs
Linkwitz Lab - Loudspeaker Design
Music and Design
Great free SPICE Emulator : SPICE-Based Analog Simulation Program - TINA-TI - TI Software Folder
Wow, what a gold mine for a newbie such as myself! Thanks! I bookmarked everyone of them in my DIY_Audio folder.
Old 1st November 2012, 11:58 AM   #35
I hope the values i found are right they are :
resonance frequency = 60Hz
Qms=1.47
Qes=0.60
Qts=0.43
so what kind of enclosures do you think will be perfect for this woofer and the tweeter remembering that the tweeter behind is sealed?
Old 1st November 2012, 01:36 PM   #36
To answer the question of the enclosure, you need to know one more parameter of the driver: Vas (or Mms). But assuming Vas=23.4 litres (Mms=20g), you have to choose a bass reflex box of 16-20 litres. The minimum vent diameter is 60 mm and the length around 100 mm. You seem to be a very lucky guy. You didn't have any idea buying the two drivers, but they fit. As far as I can see, I even predict, that the result without any additional equalizing will be already quite good!
If you have a free air impedance plot of the woofer, please post it.
Old 1st November 2012, 01:45 PM   #37
balerit is offline balerit  South Africa
balerit's Avatar
Sorry but not a good idea to mix 4 and 8 ohm speakers.
Mac
Old 1st November 2012, 01:50 PM   #38
i have the plot, i made it using excell but i'm not so sure about its correctness, because the impedance at resonance is only 13 ohm. In order to make it i used a wien bridge oscillator where i adjusted two potenziometers to vary the frequency, in the output of the amplifier i connected a resistor of 173.6 ohm, measured with multimeter, and then the woofer, i took the voltage across the woofer for every frequency going from 10hz to 100hz with steps of 5hz and from 100hz to 1kHz with steps of 100Hz, then i inverted the formula for the resistor divider to find the impedance of the woofer. The voltage was measured with a common digital multimeter set to AC measures. Did i do right? because if i did wrong also the Qts is wrong.
How can i upload the plot?
Old 1st November 2012, 01:52 PM   #39
plot
Old 1st November 2012, 02:33 PM   #40
Difficult to say. 13 Ohm at 60 Hz is ok, but I'm not sure about the width. Compare your results with the simulation.
loudspeaker enclosure design davidel94 Multi-Way 5 9th September 2012 03:26 PM
Guitar amp loudspeaker(s) enclosure akis Instruments and Amps 13 25th October 2011 06:57 PM
Loudspeaker Enclosure guru_jeff Multi-Way 6 20th December 2006 09:20 PM
RJ loudspeaker enclosure plovati Multi-Way 13 1st September 2005 02:51 AM
3-way 10/12" Loudspeaker Enclosure makaveli17 Multi-Way 0 7th April 2004 10:47 PM
Copyright ©1999-2017 diyAudio
