loudspeaker enclosure design - Page 2 - diyAudio
Old 2nd October 2012, 11:55 PM   #11
HT-22: Fs 1.5kHz, recommended xover 2.5kHz second order.
Old 4th October 2012, 07:43 PM   #12
Just wanted to mention that the woofer is 4 ohm and the tweeter is 8 ohm... keep that in mind. I don't like high Q woofers. I'm not familiar with that tweeter, but have trouble believing it will sound good. Do you already have these? If not, I would reconsider both choices. Not that you can't make this work, but as mentioned, it might not be worth the effort.
Old 7th October 2012, 11:58 AM   #13
why it won't work in bass reflex?
Old 7th October 2012, 01:19 PM   #14
Dissi is offline Dissi  Switzerland
Bass reflex requires a driver with Qts between 0.2 and 0.5. It is impossible to get an acceptable frequency response with a driver having a Qts of 1.
Old 7th October 2012, 04:48 PM   #15
balerit is offline balerit  South Africa
balerit's Avatar
You can't use 4 ohm with 8 ohm it'll upset the crossover
Old 7th October 2012, 05:29 PM   #16
No, he uses an active crossover and 4 or 8 ohm has no importance!
Old 7th October 2012, 08:02 PM   #17
balerit's Avatar
The sensitivities will be way out.
Old 7th October 2012, 10:13 PM   #18
diyAudio Member RIP
Originally Posted by tvrgeek View Post
Well Sreten, we will just have to disagree with the description on this one.
Given your ignoring the clear evidence (around 4KHz Fs, impedance is shown),
making incorrect assumptions and trotting out the usual glib statements about
tweeter Fs and x/o frequency (which simply isn't true for tweeters designed
to be used with a single cap), it seems head in the sand "disagreement".
rgds, sreten.
Picking holes in the top end of a $2.50 tweeter is churlish, and its
not break up according to the CSD, Zaph|Audio Ctrl F "nuance"
Old 7th October 2012, 11:09 PM   #19
Once again, Davidel94 uses an active crossover. Discussions about passive filtering of cheap tweeters do not help and do not belong here!
Old 7th October 2012, 11:56 PM   #20
diyAudio Member RIP
Yes they do, as I posted active is a waste of time in this case.
rgds, sreten.
BOLD ABUSE IS NOT AS BAD AS CAPITAL, but italics are best for emphasis.
loudspeaker enclosure design davidel94 Multi-Way 5 9th September 2012 03:26 PM
Guitar amp loudspeaker(s) enclosure akis Instruments and Amps 13 25th October 2011 06:57 PM
Loudspeaker Enclosure guru_jeff Multi-Way 6 20th December 2006 09:20 PM
RJ loudspeaker enclosure plovati Multi-Way 13 1st September 2005 02:51 AM
3-way 10/12" Loudspeaker Enclosure makaveli17 Multi-Way 0 7th April 2004 10:47 PM
Copyright 1999-2017 diyAudio
