How to fix Technics SB-T20 Speakers? - Page 2 - diyAudio
Old 6th February 2014, 12:25 AM   #11
And don't keep playing them because the foam will fail right next to your repair. I haven't done mine cause I'm not experienced enough yet to take on a driver that does not readily allow for dust cap removal to shim the voice coil. It can be done, they say.
Old 6th February 2014, 12:41 AM   #12
Replacing the foam isn't difficult. The foam surrounds are inexpensive, and the kit will even come with the correct glue.
The hard part is cleaning the old glue off the basket. I glued the cone to the surround first, and then carefully centered the cone while gluing the surround to the metal basket. Done. Works fine.
Old 6th February 2014, 12:55 AM   #13
Can anyone provide a link to somewhere I could order a kit like this? I have no idea where you would buy such a thing retail. There are electronic supply stores where I live. I suppose I could call and ask if they have them.
Old 6th February 2014, 03:33 PM   #14
Lojzek is offline Lojzek  Croatia
Lojzek's Avatar
Chellspecker,
First make sure to measure your old surrounds and then
you will look for a replacement of similar values. Just for
illustration.
Old 6th February 2014, 03:53 PM   #15
Googled "replacement speaker surround". Came up with this: DIY Speaker Repair Kits, Refoam, Re-edge, New Foam Surrounds
FS: Ultra Rare Technics SB-7000A speakers! Zero Cool Swap Meet 7 14th September 2008 10:46 PM
Technics SB-K43 dantheman6690 Multi-Way 4 31st May 2008 08:27 AM
Technics SB-6000 Blindet Full Range 0 22nd April 2007 10:06 PM
Technics SB-T20 The_Mox00 Multi-Way 2 10th November 2006 10:19 PM
Replacing Cones on a Technics SB-T200 debarros Parts 2 14th June 2005 06:22 AM
Copyright 1999-2017 diyAudio
