#21 |
frugal-phile(tm)
Bit an EQ like the ADC subtracts a whole lot of information from the music. Jason can probably tweak the XO to acheive the same results that the WQ does.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#22 |
That's strange to be shelving down the High frequencies....older people usually prefer boosted HF
That driver measures flat. I guess I could shape the top end but he would have to send the crossover to me. I don't know that it would sound much better that doing it with eq. I suppose if he wanted a kick at the bottom we could retune the port. As it is now, it's a flat alignment, but he is getting no room gain.
I LIKE YOU
#23 |
Well, we need to pick out a driver first and see. If you could keep the length, we can find a driver that will really kick with good sensitivity.
I LIKE YOU
#24 |
Melo--you are right about the higher frequency loss; mine was about gone--however--a pair of very sophisticated,small hearing aids fixed that problem. But even in my youth I did not like a lot of HF in my music and always cut the treble a bit and upped the bass a bit so I guess thats just me. Forgive me--I thought you were joking about the tube idea. If and when you feel like talking about it--i'm ready to listen closely.
Dave--You are absolutely right but i'm not listening to critical recordings on vinyl. I download from Itunes at 240 bitrate, burn playlists to CD and let her rip !!! I am thinking of getting a small PC for the garage and hooking it directly to my amp but thats probably as fancy as i'll ever get. Let me sum it like this--my idea of a good time would be a set of Altec VOTT's w/ bass bins in an empty aircraft hanger !!!
#25 |
Just get an iPad. I have one. Very low noise. Good enough for the garage.
Or any tablet will do. Or I guess any smart phone for that matter. Yes, I'm serious about the tube. I'll PM you, we will come up with something
I LIKE YOU
#26 |
I LIKE YOU
#27 |
Once again I must thank Melo Theory for designing the sub to fit my rather tight requirements; none of this would have been possible without his help and design expertise. The entire three piece system just works great in my garage for which it was designed. I am grateful for your assistance.
#28 |
Forgot to mention: sub speaker is a 12" Dayton Classic; amp is a Yung SD 300watt model; port is Precision Port 4" adjustable kit, all from Parts Express. Concrete form tube and 3/4"MDF from Home Depot.
#29 | |
#30 |
Sub is performing well. I have moved it to several locations around the garage and for some reason it sounds better up high (see pic above). I have no idea why this is so. Anyone have any thoughts about this ?? I have always believed that subs do better close to the floor but not so in this case
| Opinions on pc/mobo "onboard spdif to Ian's FIFO kit" or "USB to WaveIO" to I2s? | edbk | PC Based | 0 | 1st May 2012 02:40 PM |
| Delivery Source for the 10cm "HR Vocal Driver" from "4722" LENS (47-lab) wanted | tiefbassuebertr | Full Range | 0 | 24th April 2012 11:14 PM |
| The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter | River757 | Multi-Way | 14 | 7th September 2011 06:41 PM |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 06:42 PM |
| Can someone explain the theory behind "sound reinforcement drivers"? | Cal Weldon | PA Systems | 30 | 18th December 2007 11:18 PM |
