Stuffing test report - Page 18 - diyAudio
Old 19th November 2012, 09:29 AM   #171
mondogenerator's Avatar
cotton balls are a great budget stuffing. I havent seen that bamboo fibre before, that could indeed be interesting to try out.
I learnt on my 1st build just how much work spray painting an MDF box was. Before i tried sealing with household emulsion I laid down probably half a dozen primer coats, same or slightly fewer for colour coat, and the same for lacquer. I found i had to wait 2 weeks at least before re-lacquering otherwise i removed far more than overspray. Tedious and it turned out ok, but not the piano gloss id hoped for.
A luthier friend recommended a 2 part setting lacquer he uses. I cant recall the brand, but it certainly wasnt cheap. However it worked a treat when he re-lacquered my faithful ol' geetar, with a brush no less.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 20th November 2012, 08:22 PM   #172
tvrgeek is offline tvrgeek  United States
#168 confirms FG works. I see two other materials mentioned, but again, no objective comparisons.
Test Signal for max power test of Class D? eem2am Class D 19 27th August 2012 09:22 AM
test the effectiveness of foam and/or stuffing in your box. Borat Multi-Way 0 30th September 2009 03:50 AM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
dc blocker test report jeapel Pass Labs 5 4th July 2007 04:46 PM
Interesting 6L6GC Test Report peritus307 Tubes / Valves 2 17th November 2006 09:27 PM
Copyright 1999-2017 diyAudio
