Old 23rd October 2003, 06:49 PM   #1
pinkmouse's Avatar
Default Tannoy Horn loading question
Hi folks
Just a quick question for research for a future project. Is anyone aware of the Horn geometry used for the Tannoy 12" co-axial system? As most will know, it uses the bass cone for horn loading for the mid/high driver, and am just curious as to if it is designed to a certain geometry, (and if so, what?), or if it sounds good purely by chance.
Anyone any ideas?
Thanks!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 27th October 2003, 09:25 AM   #2
mikee12345's Avatar
Default since ive never seen one..
u cud draw it up as a table in excel of the wooden expansions,and see what sort of curve it is,then make equivalent exponential etc flares to compare to
Old 28th October 2003, 03:24 PM   #3
usekgb is offline usekgb  United States
usekgb's Avatar
These are fun drivers to work with. I don't know the exact horn geometry, but the LF section looks sort of like an exponential horn geometry. Steep in the center, and gradually flattenting out towards the edges. The biggest advantage to the Tannoy Dual-Concentric TM drivers is that they create a good time-aligned point source driver. You don't have to worry about driver spacing causing comb filtering and phasing issues. And, I can tell you, those HF sections in the Tannoys are plenty efficient without horn-loading them.
Zach
Old 30th October 2003, 08:27 AM   #4
pinkmouse's Avatar
Hi folks, and thanks for your replies
The reason this came up was that I have just started a Part time degree in Design, and the workshops in college are fully equiped for plastics and ceramics, as well as the usual wood and metalwork stuff, and to me the obvious easy thing to have a play with would be a mid/high horn.
Having owned a pair of Tannoys years ago, I remember well the sweet sound of the horn loaded co-ax, and I thought this would be a good place to start playing with my own designs. The idea of simply copying the flare rate of the cone looks do-able, but what I would really need for that is a photo of one of those half sectioned drivers that used to appear in marketing stuff.
I will probably be using a JBL pro compression driver for first experiments, maybe upgrading to the TAD if successful!
However, to broaden the subject, if anyone has any info on making compression drivers, that might be fun to have a go with as well
Al
Old 30th October 2003, 08:43 AM   #5
Brett's Avatar
Your wish is my command.
Old 30th October 2003, 08:50 AM   #6
Brett's Avatar
And another....
Old 30th October 2003, 08:57 AM   #7
pinkmouse's Avatar
Spot on mate!
The second pic is the one I remember, but the first one looks even better, as it is a straight on shot, making curve tracing easier.
Cheers!
Al
Old 30th October 2003, 05:31 PM   #8
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Default a few random thoughts
Ceramic horns?
That is just too cool.
If you come up with a design you are particularly fond of you should consider making positive and negative profiles for making molds and being able to hook up some of us other DIY guys.
Ceramic besides making a nice horn in itself also seems like it would make a nice mold for gypsum plaster or resin.
Which Tanoys did you own? Ive placed sets in a number of broadcast and studio environments. They are one of my favorite brands.
The curve in the section looks kind of like a section from an ellipse. Are you thinking about tractrix at all?
Old 30th October 2003, 06:56 PM   #9
panos29 is offline panos29  Greece
panos29's Avatar
Send a message via ICQ to panos29 Send a message via Yahoo to panos29
Default Y;ummy pic
Hey Brett great pic! Since I own 3 of these beauties HPD385) I would love to have tis pic in higher resolution(to my email ) as I am about to totaly dissasemble it for cleaning and adjustment but the mafnet is hard to open, I thought a pic of the inside might help me to se why.
Panos
Old 30th October 2003, 10:27 PM   #10
Brett's Avatar
Default Re: Y;ummy pic
I used to own some HPD385's, but I sold them about 18 months ago, when I went to horns. Now I only own a single Red 12, which I might get a friend to design a TL cab for and put it in the corner of my bedroom. Unless I ever find a mate cheap enough.
Send me a PM with your email addy and I'll send them off later.
If you go to the Keiwa site, and scroll down to "Roll Surrounds, Driver Construction, Crossovers, & Curiosities" there are a couple of links where an HPD has been disassembled for surround replacement. These might show you in more detail what you're looking for. Lots of other cool Tannoy stuff on the site too.
There is also another cross-section pic here
Two drivers loading the same horn. Tyimo Full Range 23 20th February 2009 03:19 PM
Horn loading a built sub qguy Subwoofers 3 25th October 2008 10:32 AM
Help with horn loading Web Wolf Multi-Way 3 25th October 2006 06:38 PM
horn-loading: 100% efficiency ?! e-side Multi-Way 54 1st August 2006 02:42 PM
Page generated in 0.12914 seconds (75.10% PHP - 24.90% MySQL) with 11 queries
