Replacement woofers needed for POLK RT2000P
I need to replace my 8" powered woofers in my RT2000P speakers (rubbing the voice coil) but Polk does not support this speaker anymore. Additionally, parts-express does not have a x-reference for the parts either.
Has anyone replaced these successfully or can you recommend a replacement that is compatible with the built in amp?
THX
Joined 2004
I'm surprised that Madisound couldn't help. Are there Polk-specific forums out there?
It's not so much compatibility with the built-in amp you need; the woofers also need to work with the cabinet volume and port dimensions. If you post good photos of the drivers front and back (and include the mounting flange diameter), perhaps someone can offer advice.
