updating crossover resistors, but which ones?
Old 16th August 2012, 09:38 AM   #1
ringo_the_hifi is offline ringo_the_hifi  United Kingdom
Default updating crossover resistors, but which ones?
Hello chaps.
I'm looking to upgrade my resistors in my Tannoy Monitor Gold crossovers... None original btw.
I have these in the tweeter section:
10R (in line with the autoformer)
20R (in line with the 10R but bypassed with a 1.5uf cap)
50R (in line with the autoformer but going straight to ground)
12R (padding for the notch filter)
..and a 6R8 strapped across + & ground in the LF
Which ones would be the most important to upgrade?
Many thanks
Old 16th August 2012, 04:41 PM   #2
DavidL is offline DavidL  United States
Banned
In my opinion? None of them.Put your upgrade money into room acoustic mods.
Old 16th August 2012, 05:28 PM   #3
bear is offline bear
expert in tautology
bear's Avatar
As long as they are all amply rated for power, most resistors will sound pretty much identical in this application.
However, almost everyone seems to notice something going on when bulk foil or bulk film type resistors are used, other processes as well, these include resistors like the Caddock and the Vishay - the ones in the plastic packages that look a bit like transistors.
But I would agree that taking care of your room's acoustics might be the first step forward.
Also make sure you have high quality caps in the xover. I'd address those before the resistors.
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 16th August 2012, 06:04 PM   #4
Cheers fellas.
Room acoustics are pretty much done. I have some standing waves in the center of the room but I'll need to get those sorted later.
Righto.. My caps are Claritycap ESA's.. looking to upgrade the first cap in the tweeter (6.8uf) with a ClarityCap MR which pretty much takes care of the majority of stuff from 1khz along with the Duelund cast resistors... These are a bit minty so just wondering which ones would be the most beneficial?
Old 16th August 2012, 06:19 PM   #5
prairieboy is offline prairieboy  Canada
prairieboy's Avatar
These might make for interesting reading ...
TannoyMG15
TannoyMG15-Up-Grade
MG15-problem
Old 16th August 2012, 10:31 PM   #6
TannoyMG15
TannoyMG15-Up-Grade
MG15-problem
Thanks for those... They have been previously studied very well my son...!
updating crossover resistors, but which ones?Hide this!Advertise here!
3 way crossover only with caps and resistors WhiteRhino Multi-Way 7 6th July 2012 04:04 AM
replacement resistors for esl57 crossover Audiofool Planars & Exotics 16 16th September 2011 03:19 PM
crossover question about resistors? scooby1 Multi-Way 2 6th September 2005 06:13 AM
Crossover resistors float Multi-Way 13 9th August 2005 07:07 PM
Crossover resistors murat Multi-Way 3 6th January 2005 01:56 PM
Copyright ©1999-2017 diyAudio
