Old 21st October 2003, 06:15 PM   #1
gary f is offline gary f  Canada
gary f's Avatar
Default Mini-Monitor Project Going On
Hi, I am now building a small mini-monitor of the highest quality possible. I build it for myself so it is almost a "cost is no object" project.
It is inspired in parts by the small sonus faber monitor and by the Hatt-SE by Tony Gee: HATT-SE at Humble Homemade Hi-fi
The idea is making a small 2 way speaker using the Seas W12CY woofer and a Scan-Speak 9300 tweeter. The cabinet will be a kind of round shape with multi layer of wood laminated with some Lead sheets in between for added mass.
Phase 1 is now completes, I have build the frame of the cabinets.
The shape is quite easy to build.
Old 21st October 2003, 06:19 PM   #2
gary f's Avatar
Default Phase 1 (suite)
As you can see, I have cut a flower shaped hole in the front pannel for good air circulation. There will be a nice front baffle to cover that later.
Old 21st October 2003, 06:19 PM   #3
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
looking good. your link is bad, but here is the fixed one:
http://home.hetnet.nl/~geenius/
Old 21st October 2003, 06:22 PM   #4
gary f's Avatar
Default Phase 2 lamination
This is a mess!!
I started to glue the wood sheets on the frame using epoxy glue. This is long and messy. This project is gonna be long...
I will put maybe 5 layers with a thin (2mm) lead sheet somewhere in the structure.
Old 21st October 2003, 06:27 PM   #5
gary f's Avatar
thank you for the link!
The cabinet will be approx 4.5 litres volume and the f3 can go as low as 55 hz approx. The reflex port will be under the cabinet.
See this tread:
Reflex port under the cabinet ??
I will design the filter later when the cabinet will be finished. I am thinking about a 2nd order (electrical) with a LC filter on the woofer at approx 2250-2500Hz.
Should I go higher or lower with the X-over point??
F
Old 21st October 2003, 06:32 PM   #6
rwagter's Avatar
Whouw,
do we share the same brain ?!
mine is build up bij separate cnc'd ribs but due to lousy cnc I'm stuck for now.
Will you use the same filter as tony?
Ralph
Old 21st October 2003, 06:38 PM   #7
I don't know if this is important enough to worry about at this stage of the project or not, but you might think about carrying that nice rounded effect all the way up to get rid of those corners at the sides of the drivers, that way if you flush mount the divers you will have practically no chance of edge diffraction on the speaker anywhere. And in my opinion when you build cost-no-object speakers for yourself, you can take whatever measures necessary to get rid of just about every known speaker plague.
But at the same time, if it is too late in the construction phase to factor that in, I know they will sound awesome with that drver selection you have going on.
And I would personally recommend you crossover at 2500 or even higher with that quality woofer. Don't give your tweeter too much to worry about.
Old 21st October 2003, 07:02 PM   #8
gary f's Avatar
Sure I will, this is the plan, the front baffle will be round with no edges.
Cutting the layers is not so long. In 2-3 hours with a jig saw, you can cut them yourself. But there will be a lot of sanding.
I will try using Tony Gee serie filter, but the tweter is not the same and the cabinet is not the same shape. I will also try my own filter.
I have access to high quality spectrum analysers and calsod so I will design a good one later.
F
Old 26th November 2003, 06:20 PM   #9
gary f's Avatar
Default lead sheet
Hi
I work on this VERY slowly
I have now laminated 2 layers of wood and started to glue the lead. Beware, i'ts toxic!
This is going OK with not so much problems but it's long and messy. The enclosure is becoming heavier and stiffer. Good!
F
Old 26th November 2003, 07:10 PM   #10
Timn8ter's Avatar
Keep going Gary! Thanks for the updates. The payoff is coming.
Accuton Mini Monitor stvnharr Multi-Way 1 28th March 2009 11:04 AM
Need recomendation for a 4in. mini monitor andy2 Multi-Way 3 17th November 2005 12:20 AM
JGs Mini Monitor - additional questions Benny the 2. Multi-Way 9 13th May 2005 01:27 PM
The A4 monitor, best mini monitor? KURT Multi-Way 5 26th April 2005 02:34 PM
Mini Monitor using Vifa drivers... nrgy Multi-Way 5 5th September 2004 12:37 AM
Page generated in 1.79889 seconds (5.43% PHP - 94.57% MySQL) with 11 queries
