Cross over help - low tweeter volume. - diyAudio
Old 14th August 2012, 11:24 AM   #1
Default Cross over help - low tweeter volume.
Hi all, first post here.
Today I picked up a pair of TDL Nucleus 3 floorstanders for a pretty good price. However, I've got them home and I think there's a problem with one of the cross overs. Please bear with me here, I am a complete noob when it comes to the internals of speakers. But I'm interested in building a few skills/knowledge.
Basically, one tweeter was much lower volume than the other. I swapped it over to the other speaker/cross over, and it sounded fine. So my conclusion is that there is a problem with the cross over.
Can anyone suggest a starting point or procedure for figuring out what the problem may be? I've attached a photo of the offending item. High frequency on top.
Very limited electronics knowledge here, so take it easy on me!
Old 14th August 2012, 11:53 AM   #2
vacuphile's Avatar
Check the wiring with an Ohm meter and if all that is fine, change the blue bits. They are bipolar capacitors and degrade over time.
An FFT of my life would show a couple of peaks and some low level harmonics, but mainly random noise.
Old 14th August 2012, 12:04 PM   #3
mondogenerator's Avatar
+1 the electrolytics may have dried out, giving a much higher resistance path through the capacitor.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 14th August 2012, 12:31 PM   #4
Thanks for the advice guys. Will pick up a multimeter tomorrow and see what I can find.
Old 15th August 2012, 10:34 AM   #5
Does anyone have any tips for extracting the capacitor from the glue that has been used to fix it to the panel? It's hard to see from the photo, but the cap and resistor have basically been half submerged in what looks like hot glue gun glue.
Maybe it would be easier to place the new cap somewhere else, and just wire to and from it? Will still be tricky to get to the resistor through the glue.
Old 15th August 2012, 11:39 AM   #6
if its hot melt glue, then you should be able to simply prise the glue from the terminal plate with the right tool. Knife, flat screwdriver, chisel?
Old 15th August 2012, 02:16 PM   #7
system7 is offline system7  United Kingdom
system7's Avatar
Electrolytics are designed to be stable to 85C, and everything evidently survived the hot glue application.
I dunked my crossovers in hot water around 60C and the hot glue came away easily if messily enough. I then dried everything carefully. Most components and circuit boards get a final wash in water as part of manufacturing, so I wasn't too worried about getting them wet.
Best Regards from Steve in Portsmouth, UK.
Old 15th August 2012, 04:07 PM   #8
Speakerholic
Cal Weldon's Avatar
That's what I would do. Good luck. It may take a bit of work but you should be happy once complete.
planet10 needs your help:
Let's help Ruth and Dave
Old 15th August 2012, 09:34 PM   #9
diyAudio Member RIP
FWIW the simplest procedure is to replace all the bipolar electrolytics
in both crossovers with new ones, possibly upgrading the treble
series capacitors to metallised film polypropylene.
Don't just fix the duff capacitor.
Heat gun on hot glued stuff works.
(Hair dryer with restricted airflow).
rgds, sreten.
Old 15th August 2012, 09:35 PM   #10
Thanks for the advice everyone. Another suggestion I had was using a hair dryer to loosen up the glue around the cap. Maybe this might be a way to get at the submerged leads? Any thoughts?
Also another question - the capacitor is labelled 6MF. I assume this means 6 micro-farads, as opposed to milli-farads which the "M" suggests? Is this a standard size? I'm struggling to find a replacement in the online stores. All seem to be 5.6 uF or 6.8 uF.
troels design: peerless hds ppb 830860 + vifa xt 25tg 30-04 : Low volume tweeter then_dude Multi-Way 55 9th October 2011 05:00 PM
Where do I cross this tweeter over? G Full Range 3 3rd April 2009 05:42 AM
Super Tweeter Cross Over..... tubenut Multi-Way 6 25th November 2005 01:34 AM
How low can I cross my tweeter? GuyPanico Multi-Way 1 7th November 2005 02:19 PM
How do you cross over really low? Nappylady Multi-Way 7 25th June 2004 08:29 PM
Copyright 1999-2017 diyAudio
