Weird frequency response measurements.
Old 9th August 2012, 10:08 PM   #1
joaoveludo is offline joaoveludo  Portugal
joaoveludo's Avatar
Default Weird frequency response measurements.
Hi.
Please, take take a look at these screenshots of ARC.
Can someone explain me that weird rise in high frequency on the HS80's?
I got them modded but they sound great to me... Could that be an indication of the NE5532's in oscillation? (they came with NJM4558's)
I took these measurements today, same room. I got both pairs of speakers working. (not at the same time )
HS80:
Mission 763 (floorstanders):
PS: I took the measurements with my diy mic based on the panasonic wm60 capsule with the linkwitz mod.
thanks.
Old 9th August 2012, 10:18 PM   #2
tvrgeek is offline tvrgeek  United States
What do you hear?
Old 9th August 2012, 10:20 PM   #3
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
It looks to be the speakers (are they active), as the second measurement seems fine. I doubt that it is oscillation, as it is s steady rise from about 3K up to 20K of nearly 12db!! Oscillation (in the audio range) I would think would show up as hash or a spike at a particular frequency.
How does it sound after the correction is applied? It certainly looks like there is some sort of boost happening in the raw measurement as I really can't see how the tweeter would be 12db more efficient at 20K that and 3K with a pretty constant slope from start to finish.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 9th August 2012, 10:24 PM   #4
joaoveludo's Avatar
I know that hs80 are bright speakers but this seems ridiculous.
i really don't hear nothing abnormal besides yamaha's natural brightnes that it always had since day one.
If i apply the correction they sound completely muffled, cymbals almost disappear. Strange no?
I don't really use arc to correct the room. i'm trying to address that problem with the "do-some-acoustic-panels" way.
Old 9th August 2012, 10:37 PM   #5
joaoveludo's Avatar
HS80's are placed higher in stands, at my head and the measurement mic's height.
Mission tweeters are about 40cm lower.
Does that help?
Old 10th August 2012, 03:31 AM   #6
just another
wintermute's Avatar
ok that changes things (a bit) . You should do a measurement of the Missions on axis with the tweeter. If possible take measurements of the HS80's with the mic in the same spot and the speaker in the same spot as the mission.
What was your measurement distance?
Tony.
Some of my photos
Old 10th August 2012, 05:47 AM   #7
markus76 is offline markus76  Germany
Banned
Could be a problem with ARC. Is this the new version with XT32?
I'd get a "second opinion" with REW or Holm.
Weird frequency response measurements.Hide this!Advertise here!
EL70 frequency response measurements tuxedocivic Full Range 46 11th May 2012 08:38 PM
in-room frequency response & transient response MCPete Multi-Way 1 8th October 2011 06:31 AM
do my frequency response measurements make any sense? JLC7 Multi-Way 481 20th August 2008 03:14 PM
Kef B200 frequency response measurements Tomac Multi-Way 0 13th January 2006 10:10 AM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
