AudioTechnology + RAAL Ribbon = "Sequence Three – Grand Reference" - Page 7 - diyAudio
Old 25th October 2012, 04:08 PM   #61
gornir is offline gornir  Sweden
gornir's Avatar
Originally Posted by 5th element View Post
I don't like saying it, but all things considered those are pretty poor distortion numbers for the 10", not to mention the rather large differences between the two of them. I'd have expected better consistency for a driver of this cost.
Yes, I agree I had high expectations for them. Even though there are some differences between the two driver samples, in my application it doesn't matter, but again at this price point I expect better consistency.
Regarding the distortion numbers I expected them to be in the same league as the ScanSpeak Revelator woofers 22W and 26W, which they doesn't seem to be if I've done my measurements correctly, which I think I have.
I haven't done any listening tests yet so I cannot subjectively comment on the woofers performance, but most likely would two ScanSpeak 22W out-perform the the AT 10" for the same price, at least when looking at the measurements.
I will do more measurements when I start the passive cross-over design and perhaps then I can find out more of the drivers behavior.
/Göran
Author of the "AudioExcite Loudspeaker Design" website
http://www.audioexcite.com
Old 13th November 2012, 04:05 AM   #62
tf1216 is offline tf1216  United States
Time for another update?
Old 14th November 2012, 07:54 PM   #63
gornir's Avatar
I haven’t had much time over to focus on the build so here isn’t that much new to report.
Currently I’m running the loudspeaker with some “quick & dirty” active filters using my DEQX HDP-3 pre-amp.
Hopefully I can continue with the work during the Christmas holidays.
/Göran
Old 12th April 2013, 05:02 PM   #64
Hello Goran,
I check your website every day to see what you are up to. What happened to the 3-way?
Old 12th April 2013, 06:47 PM   #65
gornir's Avatar
Hello Goran,
I'm working on it!
In fact I have waited for cross-over components for ages now, but they finally arrived this week. Soon I will start some listening tests with a passive cross-over design.
Also, I’m building some front covers for the loudspeaker. As soon as I have some time over, I will write a status update on the website.
Another reason for the delay has been the work on this design Concentric Three – M5 Construction! and some other consulting stuff.
/Göran
Old 12th April 2013, 06:53 PM   #66
Thank you for the update.
Were any Accutons or high-efficiency drivers involved in your consulting work?
Old 10th July 2013, 02:29 PM   #67
Hello gornir,
How are things going?
Old 12th July 2013, 11:02 AM   #68
gornir's Avatar
Hello gornir,
Everything is in place!
  • The enclosures are finished, including the front covers.
  • A ton of measurements are made.
  • Two different cross-overs are simulated and ready to be tested.
  • The cross-over components are purchased for the above two cross-over simulations.
But......... I haven't had time to actually build the test cross-overs, listen to them and fine tune them yet. Other stuff has come in between.
My best guess now is that it will be an autumn project to finish them completely.
However the "Concentric Three – M5 Construction" is finished and sounds great. I've started to do a write-up on them, but I can't say when I have time to publish it.
/Göran
Old 15th July 2013, 07:20 PM   #69
Thanks for the reply. Good luck with your work
Old 15th July 2013, 09:48 PM   #70
Jozua is offline Jozua  South Africa
Hi
I am also following this thread with interest as I am seriously thinking of importing the bass drivers.
Troels seems to think they are excellent
Jozua
AudioTechnology 15H + ScanSpeak Beryllium = Sequence Two – Monitor BE! gornir Multi-Way 14 16th August 2012 08:32 AM
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs Thesoundmen Swap Meet 1 27th July 2011 04:21 AM
Anyone own KEF Reference 104/2 "Raymond Cooke Special Editions?" glasswolf Multi-Way 0 4th October 2010 03:14 PM
Audiotechnology 10" Jorgitox Vendor's Bazaar 0 9th September 2009 08:55 PM
FS: very nice RAAL "FlatFoil" ribbon tweeters {NIB }, with custom made front plate yairf Swap Meet 3 2nd June 2009 10:25 AM
Copyright ©1999-2017 diyAudio
