AudioTechnology + RAAL Ribbon = "Sequence Three – Grand Reference" - Page 6 - diyAudio
Old 25th September 2012, 08:30 AM   #51
David Gatti's Avatar
Very, very nice work!
Old 25th September 2012, 02:30 PM   #52
Bassivus's Avatar
Very nice!
Some listening impressions already?
...is I disappear. There is ONLY the music.
Old 25th September 2012, 05:15 PM   #53
gornir is offline gornir  Sweden
gornir's Avatar
Hi guys,
Thank you!
Hopefully I will find time this weekend to finish the second loudspeaker and later on do some frequency and distortion measurements on the 10C woofer.
I haven't done any listening tests yet, but I will as soon as I hook them up to my active DEQX system. I use the DEQX to get the feeling how the drivers behave and to quickly test different cross-over points etc.
When I'm done with the DEQX testing I will do the frequency measurements that will be used for the passive cross-over simulation and design .
/Göran
Author of the "AudioExcite Loudspeaker Design" website
http://www.audioexcite.com
Old 12th October 2012, 06:20 PM   #54
Jozua is offline Jozua  South Africa
Hi
Any news re progress
Jozua
Old 14th October 2012, 08:58 AM   #55
gornir's Avatar
Originally Posted by Jozua View Post
Hi
Jozua
The project is moving forward, but slowly.
Both loudspeaker cabinets are finished. Some minor adjustments remain e.g. building front covers for them and fixing some beauty spots.
I’ve done the woofer measurements as well as some DEQX measurements, but I haven’t had the time to do the write-up on the woofers and create correction filters for the DEQX.
Soon I hope I will have them up and running actively crossed-over with the DEQX pre-amp.
These loudspeakers are a pain in the *** to measure since they without cross-overs weigh about 55kg each and are tough to move around!
Currently I’m also working with a new two-way called “Revelation Two – Monitor MkII”. It uses the ScanSpeak 15W/4531G00 mid-woofer and the D3004/660000 tweeter. So far everything looks good and I’m in the final voicing stage of the design process.
I’ve attached some pictures of the Grand Reference build. In real life the loudspeaker looks darker than the picture. They are dark grey in daylight and almost black in the evening.
/Göran
Old 14th October 2012, 09:59 AM   #56
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Old 14th October 2012, 07:37 PM   #57
gornir's Avatar
Originally Posted by tinitus View Post
I take it as a compliment!
/Göran
Old 14th October 2012, 07:43 PM   #58
its just nice to see a real speaker
Old 23rd October 2012, 08:09 PM   #59
gornir's Avatar
Hi everone,
Here's a small status update of the loudspeaker build!
AudioTechnology 10C772510KAP Measurements!
Sequence Three – Grand Reference Construction Update4!
The last driver measurement to publish for the Sequence Three – Grand Reference loudspeaker design is the AudioTechnology 10C772510KAP 10” woofer. This woofer uses a very stiff rigid thick (2mm) sandwich cone. For its size it has an extended flat frequency response, with a cone break-up at approximately 1.9kHz.
Besides Troel Gravesens measurements, I haven’t seen any independent measurements made for this woofer. One thing that differs my measurements from Troels is that his cone break-up occurs higher up in frequency (2.5kHz), compared to my measurements.
In my case this is not an issue since I intend to cross-over the woofer to the mid-range somewhere between 3-400Hz. Even though the frequency response is very flat I doubt anyone would use this woofer any higher than 5-600Hz.
Next, I will connect the Sequence Three – Grand Reference loudspeaker to my active DEQX HDP-3 system and start some listening and cross-over testing.
/Göran
Old 23rd October 2012, 09:48 PM   #60
5th element's Avatar
I don't like saying it, but all things considered those are pretty poor distortion numbers for the 10", not to mention the rather large differences between the two of them. I'd have expected better consistency for a driver of this cost.
AudioTechnology 15H + ScanSpeak Beryllium = Sequence Two – Monitor BE! gornir Multi-Way 14 16th August 2012 08:32 AM
For Sale : dvb-projekt "Reference" TDA1541A DAC PCBs Thesoundmen Swap Meet 1 27th July 2011 04:21 AM
Anyone own KEF Reference 104/2 "Raymond Cooke Special Editions?" glasswolf Multi-Way 0 4th October 2010 03:14 PM
Audiotechnology 10" Jorgitox Vendor's Bazaar 0 9th September 2009 08:55 PM
FS: very nice RAAL "FlatFoil" ribbon tweeters {NIB }, with custom made front plate yairf Swap Meet 3 2nd June 2009 10:25 AM
Copyright ©1999-2017 diyAudio
