Square Pegs
Square Pegs
Old 5th November 2013, 06:32 PM   #571
gedlee is offline gedlee  United States
gedlee's Avatar
Originally Posted by Patrick Bateman View Post
If in doubt, read the patent
Short of reading the patent, the "instantaneous flare rate" would be the slope of the bounding curve? Or the second derivative? It has to be one or the other because higher order derivatives are not guaranteed to exist or be finite.
Stated in these terms, an OS waveguide has the lowest 2nd derivative given an initial slope of zero and a final slope of whatever the design angle is. Since the internal diffraction is proportional to the 2nd derivative, the OS has the lowest internal diffraction for the two given slope conditions.
Earl Geddes Gedlee Website
Old 6th November 2013, 10:48 AM   #572
JLH is offline JLH  United States
JLH's Avatar
Originally Posted by mefistofelez View Post
Hi JLH,
thank you for the response. My English must be really poor, since it appears that I could not get my question across.
I do understand how you and Patrick Bateman are using Hornresponse to calculate the "local area of expansion (the local flare rate)" as you describe it.
However, I was trying to understand the concept of local flare rate a the application thereof to the driver loading. I have derived a relationship based on my assumption of what the Synergy patent is trying to disclose, but the resulting curves when overlaid on Patrick Bateman's curves, purportedly derived by your method from Hornresponse, did not agree. Hence my question regarding the underlying concept, to enable me to check my work.
However, yesterday I discovered Tom Danley's "A White Paper on Danley Sound Labs Tapped Horn and Synergy Horn Technologies", wherein Fig. 4 illustrates "Approximate driver loading of SH-50 based on where along the horn the driver is located". When I entered the parameters of SH-50, a square conical horn with 50 deg included angle, to my formula, and overlaid the resulting curve on Fig. 4, I have a match.
Based on the foregoing, I will now proceed under the false assumption that my understanding is correct. ;-)
Kindest regards,
M
Yes, the white paper does a good job of explaining how the conical horn has a variable flare rate as you move down the horn. The conical horn is not a fixed flare rate horn like the exponential, hyperbolic, tractrix, or LeCleach.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 22nd November 2013, 12:07 AM   #573
kenpeter is offline kenpeter  United States
Really hard to phase plug a single driver to a line.
Paraline seems one of the few reasonable ways
to avoid crazy path contortions.
But when we synergy 2 drivers to appear from a
point source rather than a line, now each phase
plug delay is self asymmetrical. Maybe this allows
other (not flat) phase plug shapes to be carved?
I'm just saying it might be worth noodling.
Like maybe a slot over a 3inch speaker with a
triangular plate between, making a greater
delay at one end. To synergy in pairs of single
apparent source. Or maybe you guys could
storm up something a little more coherant?
We are also smearing the reflection of the slot
back to the driver, which might be a good thing.
Not all paths of one length to sudden expansion.
But curved delay for a curved wavefront.
Old 22nd November 2013, 12:21 AM   #574
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
other (not flat) phase plug shapes to be carved.
delay at the ends. Or maybe you guys could
When I put a BG NEO 8 in a Paraline I noticed something odd -
The polar response *in* the Paraline was better than the polar response 'naked'.
I *did* lose some efficiency, but if good polars are a goal, there's some interesting possibilities.
Another thought I had was to do the Paraline in reverse:
A Paraline takes a circular wavefront, a compression driver, and it makes it ribbon shaped.
But there's nothing to stop you from going the other way:
Take a ribbon shaped diaphragm, and make it a circle.
^^ picture this with a ribbon at the exit instead of the entrance
This could allow some very interesting loudspeakers, such as a big Raven ribbon loading a circular waveguide.
The BG drivers are almost ideal though, because there's no cavity underneath the diaphragm, like there is in a ribbon.
Old 22nd November 2013, 12:54 AM   #575
HeatMiser is offline HeatMiser  United States
Patrick, do you get the impression that a Paraline produces something strongly resembling a cylindrical wavefront? Does SPL drop off smoothly as one listens off-axis toward the top or bottom of the slot (allowing of course for some diffraction effects due to the slot needing to terminate in some manner) or is there the more usual interference and comb filtering that messes up the high end first? Does the wavefront emitting from a Paraline "want" to travel straight like a laser beam, from a perspective of vertical directivity? Or is it more like an infinite number of point sources that spray in all directions, with the vertical directivity arising from self-interference and lobing?
I do realize I'm asking a possibly complex question about sound propagation in not-very-precise language and sort of hoping your listening or your understanding of the theory hints at an answer. I'd appreciate any thoughts.
Old 22nd November 2013, 08:08 PM   #576
weltersys is offline weltersys  United States
weltersys's Avatar
Originally Posted by HeatMiser View Post
1)Patrick, do you get the impression that a Paraline produces something strongly resembling a cylindrical wavefront?
2) Does SPL drop off smoothly as one listens off-axis toward the top or bottom of the slot (allowing of course for some diffraction effects due to the slot needing to terminate in some manner) or is there the more usual interference and comb filtering that messes up the high end first?
3)Does the wavefront emitting from a Paraline "want" to travel straight like a laser beam, from a perspective of vertical directivity? Or is it more like an infinite number of point sources that spray in all directions, with the vertical directivity arising from self-interference and lobing?
1) Not Patrick, but I have done a lot of Paraline measurements.
The wavefront at high frequencies resembles a portion of a cylinder.
2) A non divergent (equal path length from driver to exit center, top and bottom) Paraline has virtually no vertical beamwidth at VHF.
The actual vertical dispersion for a single 20 centimeter tall Paraline would be roughly 5 degrees at 16 kHz going to near 180 degrees below 1000 Hz.
3) The vertical directivity is a result of the Paraline equal path length resulting in a planar wavefront which diffracts horizontally, the horizontal dispersion controlled by the waveguide angle.
Old 22nd November 2013, 08:18 PM   #577
weltersys's Avatar
Patrick,
Other than being "interesting", what possible reason would you have to take a ribbon (which the Paraline emulates in polar response) and then convert it (with attendant losses and frequency response peaks and dips) to the radiation pattern of a compression driver that would do a far better job at driving a circular waveguide?
Your idea of "better polar response" is often at odds with what I find to be better, could you show the BG NEO 8 raw polar response compared to the Paraline?
Art
Old 22nd November 2013, 08:34 PM   #578
[QUOTE=weltersys;3713174]Patrick,
Other than being "interesting", what possible reason would you have to take a ribbon (which the Paraline emulates in polar response) and then convert it (with attendant losses and frequency response peaks and dips) to the radiation pattern of a compression driver that would do a far better job at driving a circular waveguide?[/img]
1) no one has done it
2) NEO8s and NEO3s sound great
3) The most compelling reason is space. I do a lot of car projects and there's a lot of situations where the sheer size of the driver becomes a problem. That was the thing that got me hooked on Paralines was the ability to turn sound 180 degrees or 360 degrees.
For the Synergy horns I'm building now I'm not using Paralines because I think that the Paraline is only useful in certain 'edge' cases.
Art
Here's the response of my NEO8s "bare". This is a special NEO8, only sold by GR Research, which is why the response looks different than what you see from PE.
On axis is yellow.
45 degrees off axis horizontally is red.
45 degrees off axis vertically is orange.
Note that the off axis drops like a rock, as illustrated by the orange line. This could be good or bad depending on your application, but it's clearly wildly asymmetric.
Here's the same driver, in a Paraline. On axis is yellow, 45 degrees off axis horizontally is red, 45 degrees off axis is orange, and the 'naked' response is grey. Note that the on-axis and the 45 degree off axis response 'tracks' each other closely. It's true that the Paraline is wiping out a lot of output above 5khz. At 10khz, the Paraline is down by 20 decibels.
One thing that kinda sucks about my measurements is that the Paraline "sounds" louder but the measurements show that the "raw" NEO8 is louder. I'm not sure what the story is there, it's possible that I may have adjusted the levels at one point. It doesn't make sense to me why the Paraline shows lower in the SPL output compared to the raw NEO8.
Old 22nd November 2013, 09:41 PM   #579
weltersys's Avatar
Makes sense to me, you ruined the forward response by putting the Paraline in front of a dipole ribbon (about the same thing as putting a folded towel in front of it), which makes the rear louder.
The response of that driver looks Monster Massive terrible .
Old 22nd November 2013, 09:42 PM   #580
the rear was sealed off. So Paraline in the front, sealed in the back.
Square PegsHide this!Advertise here!
My Wave Isn't Square. Troncones Tubes / Valves 186 28th August 2014 12:04 PM
What gives with this square wave? martyh Tubes / Valves 23 21st January 2010 09:22 PM
Why are almost all sub boxes square elambert Subwoofers 12 28th May 2005 08:49 PM
Square wave Prune Everything Else 11 28th June 2004 06:17 AM
