Old 3rd August 2012, 09:02 AM   #1
jaya000 is offline jaya000  India
Default 2 Way Passive Crossover for PA
Want to design passive crossover for PA 2 way speaker system.
I will measure the thiel small parameters of the 12" woofer. For Compression Driver, thinking of testing it with horn for thiel-small parameters. Then to use xover pro( bass box pro) to design the passive crossover.
want to design based on actual driver parameters instead of text book crossover. is this ok? or any other method will be better.
Old 3rd August 2012, 10:13 AM   #2
norman bates's Avatar
it won't be easy. The 12" has an increasing Impedance curve. It is not a simple 8 ohm resistor. And you are probably going to have to really pad down the compression driver.
I'd use a 24db Linkwitz Riley active crossover.
Even then, you are going to need a bunch of hf boost to get high end out of the compression driver, unless you are using a horn with a very narrow dispersion, and if you do that narrow dispersion horn, you will not have highs off to the sides.
The only tip I can give you is to cross at 1,200hz.
Norman
Old 3rd August 2012, 10:28 AM   #3
Thanks Norman,,
The 12" speaker is having linear frequency response upto 4 khz. I checked this with LMS. It has copper cap inside. So i was thinking just to crossover above 3 khz.
Old 4th August 2012, 12:57 PM   #4
Well, a 12" loses directivity above 1.2khz, however, that doesn't stop manufacturers from crossing above that. And by crossing above 1,200hz, it allows more power to go to the compression driver without blowing.
Hey, it's your ears, you may like crossing that high depending on preferences and goals.
Norman
Old 5th August 2012, 01:32 PM   #5
Norman
Nice explanation. If i crossover at 1200 hz, i need to use 2" CD for it. right?
But people say it blows quickly.
Old 5th August 2012, 02:23 PM   #6
BMS make four 1" compression drivers (2 neos & 2 ferrites) with 1.75" voice coils which are ok to use down to 1200Hz.
Old 6th August 2012, 04:12 AM   #7
djk is offline djk
djk's Avatar
A typical 12" woofer has about 60° dispersion at 1.6Khz, that is what I would use for PA.
The JBL 4425 studio monitor crosses over at 1.2Khz to a 100° x 100° horn, the 12" woofer is about 100° at 950hz.
It will sound the best to match the pattern on the horn (and Di figure) with the pattern on the woofer (and Di figure) at the crossover point.
What pattern were you considering for the horn?
An interesting horn for PA use might be the P-Audio PH-180
http://www.loudspeakersplus.com/pdfs/PH-180.pdf
It has 100°H below its center axis, and 50°H above its center axis, the total vertical dispersion is 60°V. With the speaker cabinet mounted on a stand it has wide coverage for those up close and narrower coverage for the back of the room, ideal for a typical rectangular room. It would work well crossed at 1.6Khz (I own a pair of these horns, less than $10 from Parts Express as #292-2576).
Candidates for the Darwin Award should not read this author.
Building PA. Need Help with Crossover. mattchevy PA Systems 10 28th May 2011 12:42 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
Passive Crossover for Passive Subwoofer? Toast_Master Subwoofers 23 30th April 2006 12:14 AM
Need help with PA crossover please!! jac2003 Multi-Way 11 1st June 2005 05:46 PM
behringer dcx + passive preamp + studio pa leifislive Digital Line Level 3 3rd March 2004 08:28 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
