Drivers pair parameters don't match
Old 31st July 2012, 01:41 AM   #1
saccharum is offline saccharum  United States
Default Driver Matching
Hi, this is my first time designing a loudspeaker so I have a few questions about driver matching. I recently purchased a pair of Peerless 830874 6.5" woofers and used PE's DATS system to measure their parameters. However, the parameter differences between the two drivers concerns me, namely the resonant frequency and the Vas.
Woofer 1: fs = 53.16 Hz, Vas = 0.5722 cu. ft.
Woofer 2: fs = 48.45 Hz, Vas = 0.6377 cu. ft.
(edited)
When designing an appropriate crossover and enclosure, which of the parameters do I use? Do I design two separate crossovers using the two resonant frequencies, or do I average them and use the same crossover? What about for the enclosure volumes?
Thanks a lot for your responses
Old 31st July 2012, 02:45 AM   #2
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
I use the factory data. The difference between your drivers is not all that much.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 31st July 2012, 04:34 AM   #3
But surely I'd be better off averaging my actual measurements than using the manufacturer's data, right? The Fs's are definitely lower than advertised.
However, the Vas's are significantly higher than the manufacturers: 37L to 12.5L. Any ideas why that might be? I used a method of adding a measured mass to the cone of the driver and having DATS calculate it from there.
Old 31st July 2012, 05:15 AM   #4
frugal-phile(tm)
planet10's Avatar
Not in my experience -- at least for name brand drivers. Your PE kit will likely be measuring the drivers at a different part of the T/S curves.
dave
Old 1st August 2012, 09:09 AM   #5
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
I would just average them and use that value, although id also repeat the tests a few times to check consistency, average those, then average the pairs averages. It should be accurate enough. Or you could just choose the larger box from each driver, and add blocks to reduce the other box to its reqd volume. As is usual here, others will im sure disagree.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Old 1st August 2012, 09:41 AM   #6
a_tewinkel is offline a_tewinkel  Netherlands
Note that the suspension compliance may increase (and Vas will also, Fs will decrease) if you drive them to full excursion for an hour or two. Could be useful to do this and measure the parameters again afterwards.
I once used a Visaton W200S as a sub. Shortly after I built it, I used it at a party. Afterwards it had a much softer suspension
Old 1st August 2012, 10:14 AM   #7
R.I.P.
too right , about this part. The values are consistent with minor
variations of Vas for a fixed cone mass. In a typical box where
Vbox < Vas they won't make much difference and the same
box should suit both drivers well.
rgds, sreten.
The drivers will probably run in to more similar values.
I'd just use the larger Vas, lower Fs, for design, the
other driver should be very near with a moderate Vbox.
Edit : specs are 48Hz, 16.7L and Qts 0.4, some would
use an average of this and the measured specifications.
Old 1st August 2012, 03:28 PM   #8
gedlee is offline gedlee  United States
gedlee's Avatar
Make sure to excersive the drivers for quite awhile before measuring them and then try to use parameters other than VAS as it is the most variant of all the parameters. In a good box design the drivers VAS will pretty much be irrelavent.
Earl Geddes Gedlee Website
Old 1st August 2012, 04:00 PM   #9
Very good point. If Vb is not << Vas, you have either a very large box, or you would be better off picking a different driver which is more suited to your goals. The point here is that in a good design, the compliance of the box dominates the compliance of the driver.
Of course there are limits to this: the volume displacement of the driver should be small compared to Vb to keep distortion low enough (see here).
Old 1st August 2012, 05:53 PM   #10
Michael Chua is offline Michael Chua  United States
Michael Chua's Avatar
Try using a Test Box instead of Adding Mass.
ampslab
Drivers pair parameters don't matchHide this!Advertise here!
Recommended sub for PC to match pair of full range monitors. samsagaz Subwoofers 5 8th June 2012 02:32 PM
How to find match for transistors Faaaast online? Some trans. parameters search site? Raze Solid State 0 13th January 2011 07:18 PM
tube tester how can i tell if have match pair? prorms Equipment & Tools 2 5th December 2008 02:06 PM
why do want a match pair of germanium transistors for a fuzz circuit?? prorms Instruments and Amps 1 27th August 2008 09:03 AM
How do you match drivers? maxw Multi-Way 9 9th July 2004 09:32 PM
