Picking crossover points - diyAudio
Old 31st July 2012, 03:17 PM   #1
tbone01 is offline tbone01  United States
Default Picking crossover points
Hello,
I am building my first pair of two way standmount speakers and was wondering if using an active crossover is a good way to pick passive crossover points?
Old 31st July 2012, 08:15 PM   #2
tvrgeek is offline tvrgeek  United States
It is how I start to get a feel where I am going. ( DCX) Even if you do, never forget to put a big blocking cap in series with the tweeter. Of course, it is not a simple translation, but it does tell you a lot about the drivers. In other words, if yo find a wonderful result at 2K 2nd order, don't expect to build a calculated 2K crossover in passive. You have to deal with the driver impedance.
Old 1st August 2012, 10:05 AM   #4
AllenB is offline AllenB  Australia
The better way to choose a crossover point for drivers is to study their features. Sometimes listening tests will help to reveal something that wasn't obvious in one of the drivers but this alone may or may not be an acceptable reason to shift a crossover point.
Old 1st August 2012, 02:15 PM   #5
I think I will abandon the idea and do it based on measurments.
Old 1st August 2012, 02:25 PM   #6
gedlee is offline gedlee  United States
gedlee's Avatar
I think that it depends on the "how" you will use to decide the crossover point. If you measure the polar response for different crossover point and find that one which yields the best polar response then this would work. Although translating that to passive can be difficult. If you have an active crossover and are only making a set for yourself then just stay with the active.
But do not use an active unit to detenrmine the crossover point by listening. It would be shear luck if that worked.
Earl Geddes Gedlee Website
Old 2nd August 2012, 12:20 AM   #7
Earl,
Would the polar response be the same with an active or passive configuration or just pretty close?
I read that the dispersion at the crossover point between the tweeter and midrange should be close to the same would you agree with that?
Old 2nd August 2012, 03:08 AM   #8
Default Exploration Path
Originally Posted by tbone01 View Post
Hello,
There is more to crossover design than just picking frequency points to divide the audio spectrum into segments. To fully explore the signal conditioning requirements for each driver, recommend use of digital crossover implemented on a computer with a sound card. Such an arrangement will allow filter slope, frequency, output level, phase, and delay and response equalization to be easily adjusted. Once marriage of the drivers has been optimized, then a decision can be rationally made as to whether use of passive components is an electrically feasible, economically attractive and acoustically acceptable alternative.
WHG
audible crossover points? gafhenderson Multi-Way 6 1st May 2012 03:15 PM
Help With Existing Crossover Points 2MuchRiceMakesMeSick Analog Line Level 1 22nd December 2011 03:08 AM
crossover points ddoyle Multi-Way 1 16th December 2006 09:33 PM
Do crossover points really mess things up? BAM Multi-Way 3 2nd June 2002 05:57 AM
crossover points ogp Multi-Way 1 17th January 2002 10:20 PM
Copyright 1999-2017 diyAudio
