I recently noticed one of my TC-50 speakers was distorting at moderate volume.
The distortion appears to come from both the woofer and tweeter. The tweeter (compared to the other channel) is dull and lacks any clarity. The woofer just plain distorts when compared to the other channel. I opened up the speaker and took a quick look at the cross-over. No signs of an leaky electrolytic's. The woofer cone around the surround looks good. The cone moves quietly and freely in and out. No visible damage. Since I have not abused the speakers in any way, is it possible / likely that this is a cross-over issue ? (bad cap) How can I determine if this is the cross-over or the drivers ? They are being driven by a 25 watt tube amp. The amp has been very reliable. I hoping someone here has experienced a similar problem. Any help or pointers would be much appreciated ! |
#2 |
Have you done the requisite switching the speakers to be sure the problem is not one channel of the electronics?
#3 | |
I did switch l/r channels and the distortion stayed on with the same speaker and so the amp/preamp can safely be ruled out. |
#4 |
If its a speaker issue you can try swapping x/o's between the speakers to see if its a x/o issue. If it is, all well and good, replace any dubious components in both channels, as the working ones won't be far off going compared to the ones that have gone if that is the case. Sadly I suspect you have damaged drivers. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#5 | |
I realized immediately after posting this that I had swapped the preamp inputs to the amp, not the speaker connects to the amp. When I switched speaker connects it was obvious one channel of the amp had a problem. A quick check of the output tubes in the R channel and I could see one tube was running very cold. These tubes have about 40 hrs on them ( NOS Phillips EL34 ) and one of them went bad. ![]() So, in the end it was a bad output tube and not the SPICA's at all. |
#6 | |
Enjoy those TC-50's! Do you run a sub with them? |
#7 |
| Speakerlab S 50's, Anyone? | Sithlord2007 | Multi-Way | 17 | 16th September 2008 11:05 PM |
| TC Sounds (aka Audiopulse) LMT TC-9 (predecessor to LMS) | DavidJanszen | Swap Meet | 1 | 5th June 2008 05:32 PM |
| strange 50's designed loudspeaker | jay1st | Multi-Way | 5 | 28th January 2008 09:50 PM |
| Need help finding 50's car radio vacuum tubes please | 65blkbkgt | Parts | 4 | 2nd January 2008 01:31 AM |
| 50'S GRETSCH tube amp scematics? | darren01 | Tubes / Valves | 1 | 2nd January 2004 12:20 PM |
