inductor placement clarification
Old 28th July 2012, 11:52 AM   #11
speaker dave is offline speaker dave  United States
speaker dave's Avatar
Just a little bit of theory, if anyone is interested, about mutual inductance.
Lets say we have two inductors each with 100 turns of wire and each with an inductance of 1 millihenry. If we put them in series, not too close together, and measure their inductance we'll see the sum of the two inductances or 2.0 mH. Now lets take the 100 turns off of one coil and wind them onto the other. We can add some copper if we need to to get to 200 turns total. Measure this new bigger inductor and we see that rather than 2.0 mH we now have 4.0! The inductance quadrupled. We can state a rule of thumb that inductance of a given form factor will go up in proportion to turns squared: 2 times the turns gives 4 times the inductance.
The difference between 2 individual and separated inductors and the single combined inductor is called mutual coupling. We could probably just take the original 2 inductors and place them touching side by side and get pretty close to the 4 mH.
Now the orrientation makes a difference. If we have the two inductors side by side and twist one of them 180 degrees we will se the total series inductance fall to less than the sum of the two. It might even approach 0 mH. This gives us a way to measure the mutual inductance. We can connect the coils in one orrientation and measure, then connect with one coil reversed and measure again. The difference is 2 x M the mutual inductance. If two coils are sufficiently far apart then both orrientations give the same reading. L1 + L2 +M is the same as L1 + L2 - M when M is 0. If we see no difference with two series connected inductors as we change connections then we have spaced or orriented them adequately.
Since the winding direction can make a difference you will sometimes see inductors or transformers with a dot at one end of the winding, to remind you to connect in the right orrientation. I have seen crossover networks where most measured good but a number had a consistant error in response. It was because a pair of coils had significant coupling and they were not being consistantly orriented in the PC board. That is, the starting end of the winding was sometimes at a particular terminal and sometimes reversed. (So sometimes we had +M and sometimes -M).
Mutual coupling can also give odd response effects with a stop band that falls for a bit and then nulls and starts to rise. This is more often the case when the inductors are in different network sections.
Finally a picture of how old time radios took advantage of this. The variometer let you turn a second coil within an outer coil. As the angle varied you could swing over a large range of inductance with the two inductances both adding and, at other angles, subtracting.
David S.
Old 28th July 2012, 12:05 PM   #12
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Originally Posted by speaker dave View Post
The variometer let you turn a second coil within an outer coil. As the angle varied you could swing over a large range of inductance with the two inductances both adding..
I think I want one, even if it's just to put on the mantlepiece and admire.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 29th July 2012, 12:03 AM   #13
Moondog55 is offline Moondog55  Australia
Moondog55's Avatar
Which is the positive end ( Signal in) of an inductor then??
And yes a serious piece of industrial art
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 29th July 2012, 12:29 PM   #14
DrDyna is offline DrDyna  United States
DrDyna's Avatar
I've always, without knowing exactly why, made an effort to always connect my coils as you say. I'm not sure if it's right, but I use the "in / start" as the end closest to the center and the "out" as the other.
As for that variable inductor, couldn't that be something useful for crossover experimentation, or do you think it'd have ill effects? It looks like a simple thing to make.
Old 29th July 2012, 02:56 PM   #15
LafeEric is offline LafeEric  United States
LafeEric's Avatar
That is an RF coil - the inductance is probably too low for audio work - though it might be interesting to try to build one for audio.
Old 29th July 2012, 10:31 PM   #16
You can certainly use the method for a quick way to find the right value for a network. For example, connect a pair of .5 or 1.0 mH inductors in series and apply it as the primary L in series with a woofer. The orientation and spacing of the two inductors will swing the combined L from nearly 4 times the single value to near 0. With an RTA you could zoom in on the best value pretty quickly, then replace it with a single inductor of matching measured value.
You can also do the same with an iron core inductor if you can slide the core in and out. Usually you can get about a 3 to 1 swing which will let you dial in the best value.
As to the question of winding direction, it makes no difference at all to the signal but is only a factor if multiple inductors are interacting. Air core inductors have no known distortion mechanisms and the iron core ones have only symmetical (odd order) distortion, so connect either way.
David S.
Old 29th July 2012, 11:40 PM   #17
Moondog55's Avatar
David S.
I suppose tho that being consistent in which end you choose as the signal in would be a better choice, even if the actual direction is unimportant, I suppose in that case whether the coil is laid RH( Clockwise) or LH(Counter-clockwise) is also of little or no significance
inductor placement clarificationHide this!Advertise here!
Inductor placement nikomail Parts 0 29th September 2011 08:02 PM
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
output inductor//resistor placement Neutrality Solid State 3 11th September 2011 05:30 PM
Inductor Placement on Xover cyberspyder Multi-Way 16 13th April 2008 09:18 PM
Newbie needs clarification MlinarS Tubes / Valves 5 9th February 2005 03:02 PM
