Hello, I had been planning a home sub project but that has been put on the backburner while my wife decides if she wants new furniture and a different living room set up(which will most likely take several months)
SOOOO, I' just build a center channel. I just built the tri trix vented a month or so ago and am very happy with the results. I have found a few pages covering a center channel build. my two questions are crossover point?? I've seen 3600Hz and 2500Hz, not sure how to determine what I would do on whatever speakers I buy. Anyone ever just use a couple good full range speakers for a center channel? I guess I could just build a tri trix sealed and it would match nicely, I don't know Any advice? music/movies |
#2 | |
Regards, WHG |
#3 |
Thanx, that makes sense. I will probably go ahead then. I think I may just order another tri trix component kit. I am thinking that I may go ahead and order another one of the tweeters as well and then make a MT tritrix for use as rear channel speakers. Assuming that the crossover would be ok. The cost of ordering the components for a single tri trix is about $100, so I might as well get the pair for another $40.
#4 |
The tritrix has the two woofers wired in series, so remember the crossover values are going to change, roughly double the capacitance and half the inductance if you use only one woofer. There will also be a small inductance change for the drivers themselves, so you might want to also subtract the Le of one woofer coil to find the right size xo inductor.
#5 |
You can't use the MTM x/o for a MT version for the rears. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#6 | ||
#7 |
The crossover part of the idea will need to be worked out then. When I started the diy speaker project I only thought that the 2 mains would work, but I am hooked and think it would be nice to have the 5.1......I will then have a completed system while I plan the next build.
Could I simply use the crossover layout from curt c's website for his tri trix MT design? |
#9 |
I've just now started learning about the complexity of crossovers so I would feel best about using an existing design.
#10 |
This is very wise. There's nothing wrong with having a couple of sets of speakers so that you can do your own experimentation but if you're only going to make one set and that's what you have to live with, better to do something that already has the engineering done.
| Full range as Center channel | thisisvv | Full Range | 13 | 20th July 2012 01:33 PM |
| Full range center channel | spartakus31 | Full Range | 3 | 1st May 2011 02:25 AM |
| Frequency range of the human voice & full range center channel speakers | jwmbro | Multi-Way | 31 | 20th January 2008 03:07 PM |
| Second driver crossover point/full range | The Paulinator | Multi-Way | 17 | 21st January 2004 07:01 AM |
