Old 19th July 2012, 07:35 PM   #1
Unimog is offline Unimog  United States
Default Effect on crossover of using drivers of different impedance than original?
If a crossover is designed to operate several drivers at certain crossover frequencies, what affect does it have on the operation of the crossover to replace those drivers with drivers of different impedance than the original? Is the result only to shift the impedance seen at the input of the crossover, or do the crossover frequencies shift also?
Old 19th July 2012, 09:06 PM   #2
expert in tautology
bear's Avatar
xover freqs shift.
also some xovers have things like frequency compensation built in... not all, but some.
there are some freeware xover simulators and of course LTSpice. LTSpice will give you a real world look at what it is doing. Plus you could plug in a generalized speaker simulation netword and get even closer, but that is overkill.
Start with a freeware or web based xover calculator to see what happens...
_-_-bear
_-_-bear
http://www.bearlabs.com [...2SJ74 Toshiba bogus asian parts - beware! ] -- Btw, I don't actually know anything, FYI --
Old 19th July 2012, 09:18 PM   #3
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Let's say you have a three way with an 8 Ohm woof, a 4 ohm mid, 8 ohm tweet. Typically the four ohm mid-range is going to be more efficient...Say 89 db woofer, 92 db mid, 89 db tweeter. The response will have a "hot-spot" in the mid-range...un-acceptable. Besides messing up the cross-over slopes, the amp will be working "harder" within these ranges.
I agree with Bear here whole-heartedly, Get some software to design with, it makes it a whole lot easier so you don't have to grind thru the math. Your select program can do it instantly. Just plug in the values for your selected drivers!!!
__________________________________________________ ____Rick........
Old 20th July 2012, 03:20 AM   #4
just another
wintermute's Avatar
A picture is worth a thousand words they say. Below is the sim of my MTM's crossover The blue trace is with the real impedance of the M's the black is what happens when I double the impedance of the M's (back to what a single M would be)
I unfortunately haven't got the actual measured response here on my work laptop, but if I did it would show that the sim is accurate.
Tony.
edit: It's not quite what I would have expected, but this isn't a simple crossover, consisting of two notches and a pseudo 2nd order electrical on the M's The bit that really surprises me is that the response above 2600 Hz is barely effected, on in that the crossover point is 2800, but checking the transfer function for just the M's shows that it is correct.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 20th July 2012, 11:18 AM   #5
speaker dave's Avatar
The biggest change is in Q. As driver impedance goes up the corner Q will rise. Corners will get sharper.
If you attenuation is mostly series resistance then it will diminish as driver Z goes up.
David S.
cartridge impedance effect with phonocube or clone fjferal Chip Amps 0 11th August 2011 06:12 PM
Effect of tweeters on ohm impedance? Flyin11 Car Audio 3 28th February 2008 05:46 AM
Tweeter impedance and crossover effect - Wharfedale Evo 30 lastig Multi-Way 1 29th January 2007 01:54 PM
Amplifier's impedance effect on XO K-amps Multi-Way 11 30th December 2006 05:32 AM
Shunt Feedback - effect on input impedance gingertube Tubes / Valves 12 6th December 2004 11:04 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
