Old 19th July 2012, 07:17 AM   #1
Banned
Default Ideas for building big round horns
I want to build a horn speaker but Stereo-lab (and other providers) won't ship to my place so I have to build them myself I want ideas about how to build big round horn using MDF slices any idea about 3D CNC or rotary machine which may be capable of cutting such a thing? I can't DIY a machine for this job, I have to find a guy with right machine to do this for me I dunno about capabilities of a 3D CNC
any help is appreciated badly
Old 19th July 2012, 07:23 AM   #2
rvrazvan's Avatar
My cheap test
I will use fibreglass at a point in time.
inspiration from here
inlowsound.com
Old 19th July 2012, 09:04 AM   #3
Tytte71 is offline Tytte71  Norway
Have you tried contacting Horns for finished horns?
If using CNC for making wood horns it would probably be cheapest and easiest to make the horns split in two parts and then glue them together. Milling or using lathe in a long narrow throath might not be feasible (depending on sizes off course).
Old 19th July 2012, 11:07 AM   #4
Banned
as I come from Iran I don't think anybody or any company would ship orders to this freakin' country I have to do it myself. I just want to know what CNC machine is capable of routing a horn with MDF slices
Old 19th July 2012, 02:07 PM   #5
You don't need a CNC machine to make a horn. Cut out the circles with a router or a jig saw,glue them together,and sand down the edges.An angle grinder with 40 grit sandpaper works well. Another way is to fill in the steps with auto body filler.
round horns
Old 19th July 2012, 02:17 PM   #6
Banned
round horns
something like this?
After spending unending hours filing, sanding and sanding some more, this is the product after priming.
Old 19th July 2012, 03:11 PM   #7
Yes,like that.
To make the sanding a bit easier,you can mount the horn vertically on a lazy susan,and use the angle grinder to rotate it as you sand.
Old 19th July 2012, 03:23 PM   #8
Banned
Yes,like that.
Thanks for the clue
I think cutting circles with CNC will speed up the project.
I have another question: what is the best way to design a Tractrix round horn?
Old 19th July 2012, 04:05 PM   #9
Single Driver Website
Old 19th July 2012, 05:00 PM   #10
Here's the approach I took:
https://sites.google.com/site/diyfir...tractrix-horns
Design is the easy part...download the spreadsheet from volvotreter's download section then graph either by hand or on the computer and print.
Lowther drivers for Big Fun horns Rafal Full Range 25 21st November 2012 01:13 AM
How to build large round front horns? Studio Au Multi-Way 73 20th November 2012 10:34 AM
Stojek Horns - DIY round BLH marekst Full Range 15 9th November 2012 12:25 PM
FS: Edgarhorn 350Hz Round Tractrix HORNS for compression drivers or cones ZERO1 Swap Meet 0 6th October 2011 06:13 AM
Full size 142Hz round tractrix horns JLH Swap Meet 19 16th May 2010 11:16 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
