Crossover?
Crossover?
Old 18th July 2012, 05:33 PM   #1
logans is offline logans
Default Crossover?
So I am attempting to build the m&k s-150thx speaker. I heard from Nrik that the tweeters have a crossover point on the 2 outer ones that cover more midrange than the middle one. If I wanted to go with an active crossover would I just put some sort of filter on the 2 outer ones to keep them from going high and a filter on the middle to cut the low? Also, do I leave the woofers bare and just run them straight to the terminal for hook up from the crossed amp? I am new to crossover designing and have no clue what I'm doing. I don't want to blow up anything!!
Old 18th July 2012, 07:48 PM   #2
I have been looking at the behringer ultra curve pro. Any thoughts on this one? Also, do they make a rca to xlr cable? I'm using the preamp outs on my Yamaha v-1400 for the front mains.
Old 18th July 2012, 08:24 PM   #3
tvrgeek is offline tvrgeek  United States
You can get XLR to RCA converters cheap from many places. Any music supply or even Parts Express. I usually make my own cables anyway.
On the DCX: I have one. Very handy for design and setup. I find it has a slight edge or digititus some would say. Others think it is just fine. Anyway, it stays on my bench as a piece of development equipment. Many like the mini-dsp boards.
Old 19th July 2012, 12:36 AM   #4
PeteMcK is offline PeteMcK
I suspect that speakers of this type would be difficult for even an experienced designer to copy
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 19th July 2012, 04:20 AM   #5
Pete I think you are correct after much research and talking with a builder friend. I think we might go for the bose L1 pro system. I've heard it and love the sound it puts out.
Crossover?Hide this!Advertise here!
More crossover help bs1777 Multi-Way 33 31st January 2011 01:36 AM
Crossover for vifa 2 way setup - how can I find out what this crossover is doing? Tino Multi-Way 11 17th May 2009 05:21 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 07:16 PM
What's this crossover? Pbassred Multi-Way 14 7th June 2005 09:25 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 06:48 AM
