SB Acoustic 3W
SB Acoustic 3W
Old 16th July 2012, 06:05 PM   #1
pierre666 is offline pierre666  Canada
Default SB Acoustic 3W
I have been looking for a while for a 3 way project using SB Acoustic drivers. I wanted to have a small tower that can deliver good base extension and a great midrange for jazz and rock music. I have heard such a project in our regional DIY annual meeting but a lot of thing wheren't exactly what I wanted...
I found eactly what I wanted at Rabu Acoustic.
3 vejs Sb Acustics
Since I am mostly a cabinet maker, I am not capable of designing crossover or calculating phases etc... Rabu Acoustic is a Danish vender of Sb Acoustic that has designed a 3 way using on each side:
1 x SB-Acoustics SB29RDC-C000-4
1 x SB12MNRX25-4
2 x SB17NRXC35-8
I know that this combinaison of drivers is a winner, the only things I am worried about is the crossover design. As I said, I know nothing about crossover design but if you read the writeup of the design, his first music test was done with AC/DC and Megadeth....!!! I am no stranger to metal music but is it possible to evaluate a crossover design with that type of music ??
Please reassure me ....I am about to start this great project!!!
THX
Old 17th July 2012, 08:13 PM   #2
jerome69 is offline jerome69  France
jerome69's Avatar
Hi Pierre !
See another project : Ekta GrandeScanSpeak 18W/
The crossover seems to be similar.
The genre of music doesn't determine the quality of listening.
I can test my loudspeaker with Pussy Cat Dolls , their disc is well done.
Classical music is better for tonal balance.
When i see this picture, no problem ...
Old 18th July 2012, 01:11 AM   #3
Inductor is offline Inductor  Portugal
Inductor's Avatar
There was this SB thread not long time ago...
http://www.diyaudio.com/forums/multi...cs-3-ways.html
Old 18th July 2012, 05:31 AM   #4
rocksteady40 is offline rocksteady40  United States
Here is yet another 3 way design wich to me looks very nice.
Zaph|Audio - SB12.3 3-Way Tower
Old 18th July 2012, 01:08 PM   #5
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
SB Acoustic 3W
One thing I find a little odd on that is the padding on the midrange is more than than on the tweeter. The tweeter is about 4.5db more efficient than the midrange, so I would have expected the tweeter to be more padded down that the mid...
Also with the dual woofers (at 89db sensitivity each) I would expect the mid with that much padding would be lacking...
Of course without seeing any measurements of the drivers on baffle I'm just speculating... I haven't tried to work out what the crossover points are with those components either.
I've just bought a pair of the SB12MNRX25-4's myself. Most impressed with the build quality!!
edit: I just modeled with my measured t/s params for the SB12 and adding 2.7 ohms series resistance drops the spl by about 2db at 5W input but also changes the QTS enough to get a much lower response out of the driver using a bigger volume (power handling is much worse though).
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Last edited by wintermute; 18th July 2012 at 01:28 PM. Reason: add comment about 4" and unibox
Old 18th July 2012, 01:57 PM   #6
jerome69's Avatar
You can see a response here ?
Old 18th July 2012, 09:51 PM   #7
just another
wintermute's Avatar
SB Acoustic 3W
That is just the SB12W ie only the mid driver, not the whole speaker if the translation of the site was correct... It does seem a bit extended on the high end though...
Tony.
Some of my photos
SB Acoustic 3WHide this!Advertise here!
TDA2030 for 3w speaker maher471 Chip Amps 15 14th July 2012 01:04 PM
SB Acoustic monitors! Build log Tigerpolis Multi-Way 21 1st December 2011 01:05 PM
SB Acoustic & Dayton lewisd Multi-Way 5 10th March 2009 05:22 PM
Source for 3W resistors seve Parts 4 12th February 2006 01:23 PM
3W instead of 5W in Aleph 5? dantwomey Pass Labs 3 31st March 2003 11:52 AM
