Old 16th July 2012, 03:13 PM   #1
Default glue or screws
Ok, this might be a newbie question.....
Why everybody uses glue for the cabinets and nobody screws?
Is it only aesthetics, or is there anything more?
I'm that guy who finds ways *not* to do things..
Old 16th July 2012, 03:19 PM   #2
Speakerholic
Cal Weldon's Avatar
If you have been involved in woodworking for a bit, you'll find that screws are more bother than they are worth for speaker cabinets. Pilot holes, pass holes, counter sinking, filling and sanding are all steps you eliminate if you use cleats, clamps and a finish nailer.
What are you building?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 16th July 2012, 03:23 PM   #3
Ok, thats an easy one:
the glue helps you keep your cabinet air-tight,
surpresses the inevitable dimensional changes in the wood
and is stronger than the glued wood anyway. (if done right!)
Screws on the other hand wont help a single bit in keeping you cabinet air-tight,
will not survive the "working" of the wood when humidity changes
and are a pita when the wall thickness is not very high.
Did that help ;-)
Michael
Old 16th July 2012, 03:40 PM   #4
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
In my K15+4, I used both: screw for robustness and glue to seal air escape.
LW1DSE
Old 16th July 2012, 03:42 PM   #5
Speakerholic
Cal Weldon's Avatar
Screws are just non-removable clamps, they add little to the structure. Glue is the strength.
Old 16th July 2012, 03:47 PM   #6
That's what I use screws for. They just stop things moving while the glue sets.
Old 16th July 2012, 03:50 PM   #7
Hopefully electronic manufacturers would read your words: I´m tired of removing lots of screws in a simple speed controller!!!
LW1DSE
Old 16th July 2012, 04:03 PM   #8
jitter is offline jitter  Netherlands
jitter's Avatar
The glue not only makes a cabinet airtight. Because the joints are fully glued from end to end and side to side, it makes them way stiffer than with just a few screws.
You may use screws to clamp the pieces together, but why not use clamps for that? It may sound rediculously short, but using bog standard wood glue, panels may only need to be clamped together for about an hour!
When using clamps you can also forgo filling and sanding the srew-holes, like Cal alreday mentioned. If you paint the cabinet, you will always see where the screw holes are, despite filling and sanding flush, especially with high gloss paint.
Old 16th July 2012, 04:39 PM   #9
Thanks everybody, I'm convinced!
I know clamps, but what are cleats and finish nailer??
Old 16th July 2012, 04:47 PM   #10
puppet is offline puppet  United States
Screws have their place. Inside the cabinet (blocking, bracing) where conventional clamping could be near impossible for instance.
Finer exterior finishes have a higher chance of success if their surfaces aren't penetrated. Fastener telegraphing can ruin an otherwise fine paint/veneered exterior finish.
Drywall screws - Not enough? DrDyna Construction Tips 34 5th July 2012 03:22 PM
Using screws instead of clamps to glue cabinets andy2 Multi-Way 22 3rd January 2011 02:31 PM
Screws crazycamber Parts 7 18th December 2010 12:26 AM
SCREWS - where to get them? smellygas Multi-Way 7 28th May 2008 02:04 AM
Do I have to use screws busterno1 Multi-Way 8 10th February 2004 08:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
