Wavecor TW030WA10
Wavecor TW030WA10
Old 16th July 2012, 12:15 AM   #1
Karl vd Berg is offline Karl vd Berg
Karl vd Berg's Avatar
Default Wavecor TW030WA10
Hi folks,
I'm trying to get a new tweeter and I was looking at the Wavecor TW030WA10, but found no info on its max power handling even at its webpage. The only thing I know, it's a 30mm dome size at 8 ohms and performs from 2kHz-30kHz at 90dB sensitivity. These numbers seem pretty ok and it cost almost the same as the Scan-Speak D2608/913000 but I need to know the Wavecor max RMS power handling.
Also to know the difference between a 30mm (Wavecor) dome and a 25mm (most tweeters) in terms of performance would be much appreciated.
And finally, which of these two models would you recommend?
Many thanks in advance!
Old 17th July 2012, 07:52 PM   #2
5th element is offline 5th element  United Kingdom
5th element's Avatar
The RMS power handling of tweeters tends to be very small 5-15 watts etc. Any kind of power rating you will see linked to tweeters is done with 'music' type signals and with an xover filter in place.
Usually distortion measurements will give you an effective way to ensure that a tweeter is capable if you are trying to see how low you can cross a specific model. If very high SPLs are your target though and you're worried of frying a tweeter then perhaps a compression driver would be more suitable.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 17th July 2012, 08:13 PM   #3
Many thanks, 5th Element!
I think I'm going to try the Scan-Speak D2608/913000 (65 euros) just to avoid bad surprises with the Wavecor (58 euros). And at least the SS is reported "80 watts".
The Wavecor, however, seemed to be a nice try and I was trying to understand how a bigger 30mm dome performs over a "regular" 25mm for most tweeters...
Cheers.
Old 17th July 2012, 09:00 PM   #4
Well it's all down to surface area and linear excursion. The slightly larger dome area will give you an off axis performance a little poorer when compared to standard 1" domes, but, all things being equal, should give you a little more head room at the bottom of its range by needing less excursion to reach the same SPL.
Now the 30mm dome apparently has 11cm² of surface area vs the 7cm² of the scan dome, which is a healthy increase. The wavecor dome apparently has 0.35mm of xmax vs the 0.5mm of the scan dome, giving the wavecore a slight edge when it comes to how much air the device can shift, however the difference isn't huge and the HDS tweeter happens to have one of the best motors around, which in this case is more likely to give you cleaner output where it counts.
Zaph has measured the TW030WA05-01 over on his blog and while decent, it isn't anything special. The tweeter you're interested in could be quite different, but based on Zaph's measurement of that tweeter I'd rather go for the HDS.
Wavecor TW030WA10Hide this!Advertise here!
Wavecor 6.5" WF160WA02 PeteMcK Multi-Way 29 19th September 2012 05:22 AM
Wavecor FR070WA01 fakeout Full Range 32 5th April 2012 10:14 PM
Anybody have experience of any Wavecor drivers? SOSx Multi-Way 3 23rd July 2010 06:47 PM
Wavecor Listening Impressions rhythmdiy Multi-Way 0 12th October 2008 06:29 PM
anybody experienced wavecor drivers? rhythmdiy Multi-Way 24 18th October 2007 01:25 PM
