Bi-amped TL question
GM
Joined 2003
>100w for below 300Hx, 100w for all above (woofer + tweeter). I was thinking that it should be modeled for one driver, but i could be wrong
Do what?! Are you saying that only one driver will be used below 300Hz and that the other 8" will be in its own cab? If so, then you're right, but as Dave noted, this isn't a good plan. If they're both open in the TL, i.e. a 2.5 way, then you need to double the pipe's cross sectional area to account for the extra driver.
GM
