Increasing transparency without tonal change
Old 14th July 2012, 04:24 PM   #1
river251 is offline river251  United States
river251's Avatar
Default Increasing transparency without tonal change
I recently obtained some ProAc One SCs, in beautiful condition in yew wood.
Compared side by side with Tablette Anniversaries, the later are more transparent. It uses different drivers.
Can I improve the transparency by upgrading parts in my One SCs? Would better caps and inductors keep the same tonal character if I carefully match values?
Thanks,
Jim
Old 14th July 2012, 04:32 PM   #2
RockLeeEV is offline RockLeeEV  Canada
No. The limitations on transparency will be from things like its drivers, cabinet, and crossover design, and ultimately room interaction, not the parts, which are mostly an aesthetic or durability consideration.
If the stock inductors are poor, switching to air cores can impart a more "dry" bass character as linearity will rise, now limited only by the driver. But it's not really a worthwhile investment. Remember that matching inductor values requires not only the Le to be the same, but also the DC resistance should stay close. Else you may find changes in the tonal balance and bass tuning. An equivalent air core to a cored inductor will require much heavier guage wire to keep DCR the same - about 10 awg air core is needed to replace a typical 14 awg cored inductor. Many Steel Laminates still have very good performance though, and will not saturate unless you use power levels much higher than the drivers' thermal and mechanical limits.
Old 14th July 2012, 04:35 PM   #3
john dozier is offline john dozier  United States
john dozier's Avatar
One of the major components of "transparency" is innate driver distortion. Another is box "talk". You are probably hearing a combination of these factors. Regards
Evil looms. Cowboy up. Kill it. Get Paid.
Old 31st July 2012, 05:05 AM   #4
river251's Avatar
A belated thanks, guys.
Jim
Increasing transparency without tonal changeHide this!Advertise here!
DEQX v. passive transparency? SashaV Multi-Way 11 14th November 2013 01:29 AM
tonal signal epilot Music 5 29th November 2011 06:25 PM
FS: Tonal Arm Lift robertjwarren Swap Meet 1 5th February 2011 07:14 AM
Transparency LineArray Planars & Exotics 13 23rd June 2010 02:40 PM
what's depth, transparency, imaging? kevinkuang Multi-Way 38 7th April 2005 04:22 PM
Copyright ©1999-2017 diyAudio
