Old 14th July 2012, 05:34 AM   #1
Thabto is offline Thabto  Italy
Default All my tweeters blown (Sony SS-FCR6500) speaker package
Hi Guys ... Need your help. I have the sony SS-FCR6500 speaker package(Front 180w, Center 150w, Rear 120w, all into 8 ohms), I am using with a Pioneer vsx-920 AVR (100w into 8ohm). Problem is all my tweeters are dead except one. The tweeters are connected parallel with a protection capacitor to the bigger drivers. What caused my tweeters to die, when they have a rating of 180w? What can I do to make sure it wont happen again? Can I modify the speakers somehow. Let me know.
Old 14th July 2012, 06:14 AM   #2
Mooly's Avatar
Tweeters usually have a low power rating of the order of a few watts only. You know the heating power of even 30 or 40 watts... a typical soldering iron for eg and so you can see that a small speaker coil can not dissipate anything like that amount of energy. Music contains little really high frequency energy which is why you see complete speakers rated at a few hundred watts. All the energy is in the bass.
One of the biggest causes of damage is clipping in the amplifier (running it to near its max output). When the amp clips, the tweeter sees what is then the equivalent of DC across it which is what burns it out.
A simulation free zone. Design it, build it, test it.
Old 14th July 2012, 12:25 PM   #3
If an amp clips the tweeter does not see the equivalent of DC.
Say I feed a transistor amp a 100Hz sine wave, no overtones or harmonics.
When we drive the amp into clipping it will put out a square wave which contains every sine wave which is a multiple of 100Hz at full rated power (or more).
No protection capacitor will or can stop the ones which are above its cut off frequency and the tweeter will just simply melt when faced with that. No DC present or needed.
This is easy to show with an analogue (ie subtractive) synthesizer.
To avoid that happening again avoid clipping by either being more cautious with the volume control or getting a substantially more powerful amp.
The rule of thumb in pro circles (studio or PA) is that the amp should be rated at at least twice the output of the speakers input capability, in your case that would be 360Wrms per channel for the fronts.
My tweeters are rated at 25W and I run them active with a 175W amp without ever having had problems.
Old 14th July 2012, 01:35 PM   #4
just another
wintermute's Avatar
The other thing you can (and should if they are going to be abused) do is put appropriately rated poly switches on the tweeters. It Will save them from a clipping amp. I unfortunately blew many tweeters at uni parties before I discovered them, but after they were installed no more problems If someone turned the amp up too high the speakers just stopped playing until it was turned down again.
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 21st October 2012, 12:08 PM   #5
Hello
When you are using a woofer connected parallel with a tweeter the back emf produced from the woofer will distroy the small power rating tweeter
I recommend using 4.7 Micro Farad capacitor AC capacitor or DC capacitor with a high voltage 250V in series with the capacitor
Why 250V ?
the capacitor can carry up to 10% of voltage rating reversed and this capacitor will be used as a high pass filter also will protect your tweeter
Ayman Ragab
Electrical Engineer
Cairo, Egypt
Old 21st October 2012, 07:40 PM   #6
seanny is offline seanny  United States
When you add a series cap you raise crossover frequency. He should turn down the volume or get a better tweeter.
Old 23rd October 2012, 02:40 AM   #7
Hi Thabto, from your description your tweeter has a first order crossover. You can protect the tweeter better if you install a 2nd order or higher crossover.
Old 23rd October 2012, 10:56 AM   #8
Won't do anything to protect a tweeter from a clipping amp.
All My Tweetrs Blown [Sony SS-FCR6500] Speaker Package Thabto Multi-Way 4 15th July 2012 07:44 AM
I'm looking for Sony midrange pair (from high-end ss-g7 / ss-g9) vintnt Swap Meet 2 22nd April 2011 09:23 AM
FS: Usher package 2 Tweeters 4 Woofers Cinellipo Swap Meet 6 29th January 2011 11:42 AM
SONY SS B-1000 speaker Bing Yang Multi-Way 4 10th April 2010 07:30 AM
Sony SS speaker mods fraserh Multi-Way 9 16th January 2009 02:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
