I have a pair of subs with 15'' drivers that normally operate in my Hi Fi system in stereo, driven by their dedicated stereo SS power amp.
From time to time I wish to use the subs for my Home Theatre system. The sub output from the HT amp is mono and I wish to operate the subs in dual mono. Is it a simple matter of placing a Y piece in the cable between amps, so the HT mono signal is split into the two phono inputs of the subs amplifier? Thanks |
#2 |
Depends on whether the sub out on your HT amp is speaker or line level - if line level, then your proposal is fine - if speaker level, you will need to attenuate it.
Cheers |
#3 |
Thanks that helps.
It is line level and works just fine into one channel. What worried me is that the Y piece effectively shorts the two phono inputs to the stereo amp together. But as you say its OK I will proceed. Cheers Chris |
| Splitting AES/EBU Signal | KCCT82 | Digital Source | 21 | 9th January 2008 10:17 AM |
| Splitting A Line Level Signal. | Noumenon | Analog Line Level | 0 | 10th August 2007 12:57 PM |
| splitting a digital signal | bser | Digital Source | 4 | 26th October 2005 05:43 PM |
| Creating a differential signal from a single-ended signal for bridged amps | Peter Daniel | Chip Amps | 45 | 8th November 2004 12:47 PM |
| Page generated in 0.06557 seconds (80.89% PHP - 19.11% MySQL) with 10 queries |
