Acoustic Research AR93s crossover: is this schematic correct?
Old 31st October 2012, 03:20 AM   #11
system7 is offline system7  United Kingdom
system7's Avatar
Originally Posted by adrewitz View Post
Apologies for the light threadjacking but I'm working on my own pair of AR93s speakers and was hoping for input from a couple of other owners.
Do you guys have any sealing material/gasket between the rim of the drivers and the speaker enclosure? I just took apart one of the speakers to replace a failed tweeter and noticed that I don't have any sealing material behind the drivers.
I had my speakers re-foamed by a shop ≈10 years ago so I don't know what was there originally. I had thought that AR was big on sealing their enclosures...
Thanks all!
The best source of information for Acoustic Research loudspeakers is :
Home Page | The Classic Speaker Pages
Some sort of roofing tar material was and still is used to glue and seal speakers in place. A cheap solution, and NOT convenient for frequent rebuilds. I don't know the brand name used, but it melts at quite low temperature.
These days a lot of firms use a soft plastic gasket to seal against air leaks. Quite important with closed box. Air leaks produce a curious shudder on bass cones, but there are a variety of plumbing materials or cardboard that would do the job quite adequately IMO. I increasingly get rubbery stuff from builders merchants.
FWIW, the schematic I came up with was simply untangling the confusing AR filter schematic. AFAIK, it is an accurate electrical representation of the crossover in a form the modern eye can follow. Just Topology really.
Best Regards from Steve in Portsmouth, UK.
Acoustic Research AR93s crossover: is this schematic correct?Hide this!Advertise here!
Acoustic research mafia1976 Multi-Way 6 16th May 2012 08:22 PM
Acoustic Research mackinthebox Multi-Way 9 6th November 2010 04:52 PM
acoustic research AR1 bassdabob Multi-Way 1 20th October 2005 11:53 AM
Acoustic Research Drivers Gavin_mi Multi-Way 2 5th September 2005 12:14 AM
Acoustic Research D400MK II schematic? jan.didden Everything Else 3 14th November 2004 04:53 PM
