First time OB builder
Old 22nd December 2012, 10:43 AM   #381
Tordenguden is offline Tordenguden  Denmark
Banned
Originally Posted by Silent Screamer View Post
Tordenguden see pics for wiring. Instead of just replacing the loopback cable for another one, the Help says it is more accurate to use a Y adaptor.
I hope you are not planning to use an Y-adapter, to mix the loop-back signal and the output for the DCN28 - because that is what it looks like on the picture ?!?
The Quad Capture "only" has 2 channels running full duplex. And on channel, is used for reference in the software, so that more accurate result can be obtained. You may use an Y-adapter at Output 1, to simultaneously send signals to both left and right input on the DCN28 - but thats a different story.
The way I do it, could be wrong, but doubt it, since I'm getting pretty good results
Microphone goes to Input 1.
Loop-back cable goes between Input 2 and Output 2.
Output 1 is for DCN28.
How did you adjust the buttons - both front and back?
Fair enough that you want to experiment with room-cancelation. But I would advice to measure between tweeter and midrange, at 1 meter distance, straight on - to begin with. When you master this - it'll be way easier to play with other possibilities thereafter
Old 23rd December 2012, 01:39 AM   #382
Silent Screamer is offline Silent Screamer  Australia
Originally Posted by studiotech View Post
Yes, yes, yes Silent. The slight downward tilt into the highs at the listening position is good! You do not want flat at your position. It will be overly bright.
Still with the wider range on the mids?
Yes still crossing over at 400Hz from mids to mids woofers. I actually thought the fuller (deeper) vocal sound of the bigger area drivers would need to be present all the way through the vocal range, but to my surprise they still seem to give a fullish sound crossed over at only 400Hz.
I could bump that up a little bit to add a bit more bass to the vocals, but I am quite happy with where they are for now. The 18WUs did exactly what I was hoping they would do. The temporary 10" Vifa I had in that 3rd speaker spot before is like chalk and cheese.
Still keen to develop the woofer cabinet a bit more, perhaps after Christmas...
Old 23rd December 2012, 02:05 AM   #383
Yes that is exactly what I was planning to do as that is the preferred option according to the Help.
That is how I currently have it set up but instead of buying a TRS to TRS cable I bought a TRS to XLR cable not knowing that it was not the same thing electrically.
Back buttons:
Ground Lift = Normal
Phantom = 48v
Hi-Z (input 1) = Off
Front buttons: see pic
Had a bit more of a play with it last night the only way to get any meaningful measurements for equalisation is near field. Perhaps down the track I will find another way but for now that seems to be te best way.
Old 24th December 2012, 02:06 AM   #384
Finally got around to doing some comparative testing of 2 x 18WUs (8 ohm) vs 4 x 18WUs (4ohm).
I know some view using 4 drivers for a mid woofer as a bit of a waste, but I think the test results show a more preferable response curve using the 4 drivers.
I plan to build a U frame similar to how they are laid out on the test baffle, and I may wind up picking up a bit more bottom end SPL, but that will just give me a bit more headroom to possible crossover slighly lower (~300Hz)
Already have an idea what the new speaker might look like...
The four 18WUs in a U frame at the top, with some kind of legs to hold it up, and provide slight angle changes.
Dangling bellow that the RAAL and the two 12MUs
Sitting on the bottom either the Pro 5100 in a H baffle, or two Dayton 15" reference series drivers in a slot loaded dipole.
Old 31st December 2012, 12:04 AM   #385
peter grillwitt is offline peter grillwitt  Germany
Hi Silent Screamer,
some commenst from my side:
1. There is a long long way to go for you... . I am now "digging in the dirt -of measurements and their interpretation" with my DCN28 & the XOver software since almost 2 years...
2. I am also using the 2nd output of the soundcard for the loop-back signal to the 2nd input. Its precise enough, there is no need to use an Y-cable (right now, maybe 1.000 hours of measurements later). Other topics are much more important before considering about differences out of the 2 outputs.
3. Please consider the directivity index of your speakers first. It could save plenty of your time. Target is a constant directivity across all the speakers. The target curve at the listening position mostly depends on the directivity index.
4. Measuring positions: 1. fixed measuring on axis near field close to the speakers (~40cm) to measure the acustical phase. It is hard to get the correct phase out of the XOver software. Minimum phase is calculated and not reliable enough. You can get the correct measured phase when you move the red cursor to the peak of the impulse response and switch of "add propagation delay" in the FFT menu. Only with the correct phase definition a correct crossover prediction can be done in the XOver. Compare the phase measurement of XOver and Arta attached. Almost the same (above 600Hz) 2. Vertical middle between the two speakers to be crossed over. (check if the phase remains the same) to define the delay of the speakers. Note: filters and EQs will shift the phase sometimes more than 360. The SPL then looks ok but the phase is not correct and the impuse responde / step respnse will be terrible - no punch/kick. Do not use 36dB, 24dB is more than enough. The higher the filter, the worse the impulse behaviour. 3. Wagged measuring at the listening position with > 15 averaged measurements finally gives you a good impression of the reality. A stationaire measurement at the listening position is useless. You can not measure the phase at the listening position because of the room, so dont worry about the phase there.
5. Start to experiment with filters (24dB L/R). Then adjust the level as Robert already explained. Then the delay to get a good impulse response. EQs only at the end of the road after you found out the behaviour of your system.
6. Windowing with multiwin is not really usefull. A window of 2ms means a resolution of 500Hz (nothing below can be shown & 500Hz between each data point)
7. Toooooooooo much stuff to explain in one post and short time... sorry
Old 31st December 2012, 12:16 AM   #386
Attached an example: Prediction of the crossover function. Same speakers, same measurement. You can move the green cursor to adjust the takeover frequencies. Only if you have the correct phase information you can see what happens with the spl.
Recommendation: Use a second software to make control meaurements.
Try to measure the correct phase of your speakers. Try slightly different positions (+/- 20cm) to be sure to know te effect. Ill go to sleep now.
File Type: jpg spl prediction with correct phase 1.jpg (436.5 KB, 120 views)
File Type: jpg spl prediction with correct phase 2.jpg (440.4 KB, 10 views)
Old 31st December 2012, 02:40 AM   #387
1. Probably even further than you think ;O)
2. Still no joy on the cable from the U.S. Might just forget about the one I have coming and order from someone else. Since the Y adaptor wasn't going to be long enough, I might get a male to male TRS and a 2F-1M TRS adaptor instead. That way I can test both ways.
3. Sorry not familiar with the term "directivity index" what is that in layman's terms?
4.1 Robert initally suggested I should start around .75m, from trying to EQ from listening position, I come to realise that I can't get usable measurements from so far back and have started using much closer measurement around .15m can probably measure a bit further back, just playing with distance.
I have yet to understand what phase is and what it does, I have been aware of it for many years, but still don't know where it fits into the scheme of things. Would like to buy a book that explains the basics, but I find most stuff online delves into things too deeply before explaining the concept of it.
It sounds like you are using the software to auto pick a crossover point. So far I have been following the advice of Greg and a few others along with some trial and error to manually set the crossover points.
4.2 Not yet up to the point of using the delay functionality in the crossover, as I am still get the basics sorted out. Robert mentioned measuring from between Tweeter and Mids to catch both.
Interesting what you say about EQ and filters and the effect on phase, I will be mindful of that once I understand what the phase should look like and learn which is more important level SPL or phase.
I'm using 24dB on one side and 36dB on the other on all of the crossover points, it gives me the flattest line to start off with before correction.
Impulse and stepped response are to do with phase?
4.3 Ok phase cant be measured at listening position effectively.
5. Ok delay before EQ got it.
6. So are you saying use DuoWin instead of MultiWin? I still dont really know what difference there is between them.
7. No worries the path to learning is sometimes slow and there is a lot I have yet to learn. One day all of these things will make perfect sense but I need to work up to that point. Thanks for all your advice and pointers
Old 31st December 2012, 03:34 AM   #388
Having just returned from a long trip to my mothers place (~2000 klms round trip) I brought back with me a sub woofer I made back in the late 90's.
I did some measurements on it with and with the the top ports in place. With the ports in place it acted more like the double band pass (Isobaric push - pull) it is, but with the top plate removed it measured very similar to the Tc Sounds Pro 5100 18".
I just used the same woofer crossover point and amplifier so I could do a back to back comparision. There was still no real bass to speak of which has me wondering if the pre amp in the DCN 28 is putting out enough voltage to really drive the 1000w per channel amp properly.
Since neither speaker is really moving the cone a great deal I have to start looking at something to explain the lack of cone movement.
Old 31st December 2012, 03:47 AM   #389
I tried both ported and sealed with a single 12" driver and there is no apparent difference between the old sub and the 18". Currently I am running one of both to do some listening tests.
I moved the port to the outside to make it easier to change between ported and sealed (port hole blocked off)
Old 31st December 2012, 09:51 AM   #390
Not really, believe me. You reached the border of your town on the trip around the world. It was the same for me, I always thought "I got it now..." Lets go together (if you like to - I think I can also learn much more)
As I said. You will not recogize a difference - yet. But be careful and always think twice before you plug and play, the inputs of the DCN are sensitive. Easiest way is to use the 2nd channel as reference, as I wrote.
Directivity means how the speaker distributes the sound. A horn for example has a high directivity. 15 out of its axis the sound level is almost zero. A subwoofer does not bundle the sound and distibutes it almost 360. At the listening position, on axis, you might have a flat SPL curve. But 15 or more out of axis you might have a very inhomogenius sound field. The first sound that arrives at your ear (on axis) is only responsible for locating the source. The quality of the sound itself is mostly created by the reflexions - more or less bundled by the directivity of the individual speakers. Its never bad, but you have to know it to take care of the correct target curve at the listening position. The target curve correlates with the directivity level to compensate it. Maybe the attached drawings might help to understand it.[/QUOTE]
0.15m is way to short for the mid & high range. You will not see the boundary effects of the speakers. Rule is ~1.5*width of the baffle to also get the baffle step into the measurement. Play around with the distance. You will recognize that EQ of small dips and peaks makes no sense because 5cm farther its completeley different. EQ in the near field makes sense to define rough trends or eliminate resonances.
Try out the following: Make a blank XOver e. g. with two output channels. No measurements. Define filters with the and play around with the quality of filters, reversing, delay, and so on. You will see that every action shifts the phase more or less. See what 24db & 36db leads to - I tried it out. A dip in the SPL and a wave in the phase.[/QUOTE]
No!!! Not at all, I am doing it comletely manually. The software helps to predict the result.
Depends on the distance and the directivity of the speakers. If the middle between mid and high is on ear axis it works well. Otherwise not. At a distance of 0.15 from the baffle it will def. not work.
SPL is more important but without a correct phase it will never sound perfect.
Everything correlates. Impulse and Step gives information about the time behaviour, shows the delay that you need to set to have all the drivers "on time".
[QUOTE=Silent Screamer;3305053]6. So are you saying use DuoWin instead of MultiWin? I still dont really know what difference there is between them.[QUOTE]
None of them.
Why havent you choosen a vertical line up of all chassis B-M-H-M-B which leads to a cylindric wave front? Might be better with less elimination and better localisation?
Best regards and a good new year!
First time OB builderHide this!Advertise here!
First time subwoofer builder broz Subwoofers 17 28th December 2011 10:09 PM
First time builder hack247.co.uk Multi-Way 0 29th May 2006 09:51 PM
First time builder question MPM Multi-Way 13 1st October 2004 11:52 PM
First time builder, need advice. apetersn Tubes / Valves 26 5th July 2004 11:20 AM
