First time OB builder
Old 12th July 2012, 08:37 AM   #11
Silent Screamer is offline Silent Screamer  Australia
I already have quite a few of the midrange 6 * 8ohm for 3 front speakers and 4 * 4 ohm for the rear four channels, so it isn't going to hurt to try it as an MTM first, as you say the baffle is hardly going to be a piece of art compared to what I have already been experimenting with.
For bass I am considering Focal Axiom 13 WX
Old 12th July 2012, 08:44 AM   #12
StigErik is offline StigErik  Norway
StigErik's Avatar
I experimented a lot with OB's, think I build more than 20 different speakers. It was a lot of fun by the way...
I didnt like MTM, found it sounded and measured better with the two mids close to each other, and run in push-pull, like this. And no baffle...
Tweeter is a Mundorf AMT2340 without front plate.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 12th July 2012, 08:47 AM   #13
_henry_ is offline _henry_  Australia
ok, if you are doing multich, please keep in mind the OB needs at least 60cm from the backwall and sidewalls. they need room to breathe.
long time ago peter daniel use focal woofer with faraday ring, i think it was audiom in his U-frame OB.
where will you buy those focal axiom?
cheers
henry
Old 12th July 2012, 08:49 AM   #14
as you can see, stigerik been thru alot of versions of his ultimate OB
prob ORIONs is the middle ground between ultimate sound and WAF
cheers
henry
Old 12th July 2012, 08:51 AM   #15
StigErik's Avatar
Yeah, I build a lot of OB's using 5" and 8" Excel drivers, and Mundorf and Beyma AMT's. And in the end I ditched the whole concept, and went for a B&G RD-75 ribbon instead ....
Old 12th July 2012, 09:41 AM   #16
Don't have to worry about WAF too much as I probably have the most understanding women on the planet. As long as I'm happy she will pretty much go along with it.
StigErik the SS illuminator are dead sexy from the back so push pull might be quite ok if done that way. Any particular reason for that arrangement, or is it purely just the measurement?
Old 12th July 2012, 09:52 AM   #17
StigErik's Avatar
There is one good reason for doing push pull with both woofers and midranges, and that is distortion reduction. Odd order harmonics are reduced with a factor up to 10 because of phase cancellation of the distortion products between the drivers.
Old 12th July 2012, 10:09 AM   #18
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by StigErik View Post
You should also read Rudolf's paper on dipoles. Too bad its only in German, ....
Offene Schallwand (OB)
Go to Downloads
By accident I had made the basic English version unaccessible for the last weeks. It is now available again.
The German version is extended - including more measurements. But if someone reads the English first, he will have no trouble "upgrading" to the German extensions.
Rudolf
www.dipolplus.de
Old 12th July 2012, 10:51 AM   #19
hi rudolf,
would you please provide us the link to your english version?
very much appreciated for your work.
cheers
henry
Old 12th July 2012, 10:55 AM   #20
ok thanks might give it a try.
First time OB builderHide this!Advertise here!
First time subwoofer builder broz Subwoofers 17 28th December 2011 10:09 PM
First time builder hack247.co.uk Multi-Way 0 29th May 2006 09:51 PM
First time builder question MPM Multi-Way 13 1st October 2004 11:52 PM
First time builder, need advice. apetersn Tubes / Valves 26 5th July 2004 11:20 AM
Copyright ©1999-2017 diyAudio
