First time OB builder - Page 27 - diyAudio
Old 14th October 2012, 11:31 AM   #261
StigErik's Avatar
It sounds just fine to me. I have tried other solutions for mid-bass without any particular success. It did have an array of eight 10" covering some ~100 to ~300 Hz. Actually, the big 21" H-frames were better to my ears.
Others do run woofers and especially midranges way above the dipole peak, and we are talking several octaves.... I would not do that because the off-axis response gets weird, but from the dipole peak and down the dipole figure-8 pattern is there, but not above.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles
Old 14th October 2012, 11:46 AM   #262
jerome69's Avatar
Thanks for the precision
Things are not so simple in OB, specially above the dipole peak...
Old 14th October 2012, 12:02 PM   #263
StigErik's Avatar
Things are not simple with OB at all! That's why its to fun to do I guess...
A lot of EQ is required to make it work properly, that's for sure. To build a dipole with drivers operating only below the dipole peak is very difficult, and it results in 4- or 5-way system.
Old 14th October 2012, 01:07 PM   #264
Originally Posted by StigErik View Post
Dipole peak described in details. In this example at 680 Hz.
Electro-acoustic models
Thanks StigEric but the math is way too complicated for me to follow, so I will need to find a dummies guide to H frames.
Studiotech pointed me in the direction of a PDF, hopefully it is a little easier to follow.
Old 14th October 2012, 03:04 PM   #265
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by jerome69 View Post
Yes 100Hz is an experimental approximative number when you use 2x10" in the H Frame It is just a point of reference for discussion.
Jerome,
I use 2x10" drivers in a H frame up to 400 Hz - without complaints. And that is almost one octave below the dipole peak. I would be thankfull if you could give the slightest hint, what kind of physics forbids going beyond 100 Hz.
Rudolf
www.dipolplus.de
Old 14th October 2012, 04:06 PM   #266
jerome69's Avatar
Rudolf : Stored energy... I made this project :
http://www.diyaudio.com/forums/multi...ml#post2643791
And I heard something wrong in the mid, and I notice a lot of stored energy (see attachments).
Easy for me to conceive, a mass of air cannot do mid, but good for bass.
I'm not alone to think this, See also the build discussions the S20z project of Gainphile on HT guide
Gainphile: S20-Z Compact Open Baffle using Zaph Kit
Why Linkwitz doesn't go up to 120Hz and now 90Hz with his Orion 4 ?
As I said some people can support the sound like MJK, you ? but for my ears the sound is not right. It can have exceptions but I have not heard it.
Old 14th October 2012, 05:00 PM   #267
Originally Posted by Silent Screamer View Post
I asked Tc Sounds for a frequency response but to date they haven't responded to my request. What does the dipole peak look like?
You're still not doing any measurements?! Speculation is ok fwiw, but hard data is necessary when building a speaker whether it's a dipole or anything else.
Old 14th October 2012, 05:03 PM   #268
Rudolf's Avatar
OK, Jerome
your "Ultimate OB" H frame is 40 cm wide and 40 cm deep. Mine is 30 cm wide and 20 cm deep. So any "trouble area" should be moved to higher frequencies, right?
Rudolf
www.dipolplus.de
Old 14th October 2012, 05:07 PM   #269
StigErik's Avatar
40x40 should place the dipole peak around 300 Hz.
My own H-baffles are 60x60 cm, and the peak is at approx 200 Hz.
Old 14th October 2012, 05:24 PM   #270
jerome69's Avatar
Yes Erik you are right, see the response curve
Ok Rudolf, yes you push higher "the trouble area" (~500-600Hz ?) but 400Hz is still high ?
First time subwoofer builder broz Subwoofers 17 28th December 2011 10:09 PM
First time builder hack247.co.uk Multi-Way 0 29th May 2006 09:51 PM
First time builder question MPM Multi-Way 13 1st October 2004 11:52 PM
First time builder, need advice. apetersn Tubes / Valves 26 5th July 2004 11:20 AM
Copyright 1999-2017 diyAudio
