Afternoon all, I've been acumilating bits and bobs for a year or two with the aim of doing some floor standers and a subwoofer.
Subwoofer is sorted, 2x KEF B139 in a T-TQWT-big thanks to Bjorno and others for the help with the deisgn-flat from 20-100Hz (out of room anyway) For the towers I have a mix of drivers available: Dynaudio 8" woofer/midbass from Volvos x4 (have mislaid the TS spec, pulled off using WT3, will post when I find them-they're used IB in the Volvo parcel shelf) Focal Utopia 6w2 x2 Paramètres haut-parleur de THIELE et SMALL, sans filtre ni ampli Dali Ribbon/Tweeter module x2 pair Famous DAL** IKO***Ribbon+Dome integrative tweeter | eBay And was planning on using two Dyns, one focal and one ribbon/tweet for each tower-am I over doing it? Would you go from the 8" down to a 5.25" or 4" or not bother with anything between the 8" and the Ikon ribbon/tweets? I could also sub in the Dyn MW162 instead of the Focal and drop the Focal into my car to replace the MW162! The cab will be a home made affair, woodwork isn't my best skill, but should be sturdy and good looking enough to pass the missus test. Crossovers are going to be a little more of a challenge-a blind amputee can solder better than me-but should prove entertaining. What would you build? |
#2 |
Have you tried simming a crossover for any of them?
I bet it would look pretty slick as a WMTWW with the Dyns top and bottom and the Focal and Tweeter in the middle. It's probably going to be a fairly complicated crossover though, could take a lot of work to get it right. I'm curious to see where this goes. |
#3 |
Haven't even thought of the crossover yet, let alone simming one-what software is available for that?-all I've found is fairly basic online calculators. Being a car audio geek I have, of course, thought about running it all active-but with a poor selection of stuff available in the UK some big passives might work out easier long term.
With regards to the cabs I was thinking of a shared chamber for the Dyns and a sealed separate chamber for the Focal-the ribbons and tweets can be "banged anywhere" as they're sealed units. Ease of construction is a bonus-limited tools (skils) and time (work 6 days and have no covered space to build so have to wait for the sun to come out ) means that any over complexity will severely delay proceedings
#4 | |||
FRD Consortium |
#5 |
Food for thought, thanks-I'll certianly have a closer look at the links provided
If going the passive route I was going to try and keep things simple to start with and then improve from thereif needed-I sell car audio and the very simple X362 crossovers from Dynaudio's 3-way kit does an admirable job. Active doesn't phase me as much, run my car active as is, though the cost of amplifiers and processors might put me in the dog house... |
#6 |
if you use the frd tools Dyna posted, you can make frd and zma files for your drivers from the plots that are usually with the specs. Personally i use Boxsim and WinISD, which are both free. I havent used speaker workshop but i expect it has similar capabilities as Boxsim, and i dont think its free. Without the spec or at least ts parameters you may have a hard time. Fine tuning and more CAN be done without sims, AllenB has a great sticky which covers the subject well.
It still amazes me every time I get something right Last edited by mondogenerator; 11th July 2012 at 05:11 PM. |
#7 |
IMO, the easiest way to go active would probably be:
Adcom GFA-7607 7 Channel Amplifier | eBay plus miniDSP 2x8 kit | miniDSP The only trouble with the X362 crossover is the same trouble with all off the shelf crossovers, they're designed assuming a purely resistive load most of the time and when driving a real speaker, it's usually pretty terrible. At least the X362 has level adjustments, so you might even end up with something listenable. It'll "function", but it'll be leagues away from "good". That's my opinion, anyway, fwiw. |
#8 | |
Speaker Workshop |
#10 | ||
![]() I already own WT3 so can design the crossovers to function at the desired freq by looking at the impedence at the freq in question. The Ikons I've already found a good link for the crossover: Dali Ikon ribbon tweeters from eBay - The Art of Sound Forum so didn't figure the rest would be too hard to piece together
| 6 sets of different drivers, what do I make these into? | makanar44 | Multi-Way | 26 | 7th March 2012 02:29 AM |
| Will active crossovers make cheap drivers sound well? | robertvalk | Multi-Way | 38 | 31st October 2008 12:01 AM |
| Would these drivers make a reasonably good 2 way? | G | Multi-Way | 8 | 23rd April 2008 10:10 AM |
| Used Drivers For Sale - Make an Offer | atalio | Swap Meet | 2 | 9th January 2007 12:22 PM |
| what can i make out of these 2 pairs of drivers?? | sqlkev | Multi-Way | 10 | 17th April 2004 11:50 PM |
