Old 16th October 2003, 05:39 PM   #1
Coolin is offline Coolin  Netherlands
Coolin's Avatar
Default Who remembers 2 foot sphere speaker
Just out of nostalgia and wondering if this kind of design was succesful soundwise.....................
(unfortunately i only saw them and didnt hear them then)
It was a while back whwn i saw them, i was about 12 jears old and it was around 1984.
They were totally white and if i remember correctly made out of something like fiberglass. They were about 2 foot in diameter and had about maby 12 3 or 4 inch speakers on the surface pointing 360 degrees H+Vertical.
The bottom had a (mid?)bass driver pointed at a piramid (which i believe was the stand as well). to spread the sound.
Does anyone remember back that far?
CO
Old 16th October 2003, 06:51 PM   #2
Over the years there have been several people making dodecahedron speakers. These weren't true sphere, but instead had 12 facets with a driver mounted in each.
Old 16th October 2003, 07:23 PM   #3
Coolin's Avatar
Default These were not flat sided.
The drivers were also a little recessed i believe.
CO
Old 16th October 2003, 08:27 PM   #4
Steven is offline Steven  Netherlands
Steven's Avatar
Hi Coolin,
Soundsphere makes that kind of speakers:
http://www.soundsphere.com/html/products.htm
Steven
Old 16th October 2003, 09:11 PM   #5
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
BBN Network Technologies makes a dodecahedron that is OEM'd by Bruel and Kjaer that is used for making noise reduction measurements, but I don’t think that’s the one your thinking of.
A while back at an AES I saw a presentation of some dodecahedrons that were built with Tannoy LGM-8 drivers. They weren’t a Tannoy product, just used the drivers. I think it was intended to do the same work as the BBN/B&K product.
I had the experience of listening to some speakers similar to what I think you were describing some tome ago. They were made by a japanese company. I think I first saw them around 1990, the letening expereince was around 1995. They had a big rack of DSP processing that went between the source and amplifiers to do some sort of special spacial enhancement. I wasn’t as impressed as the "specialists" who seemed very excited about them.
The room also had a set of JBL 4412 in it that I thought sounded much better.
I just found this web site:
http://www.oddnoise.com/spheres.html
This is a photo of the Bruel and Kjaer 4296:
Old 16th October 2003, 09:33 PM   #6
Da5id4Vz's Avatar
Well I give up, cant find them anywhere. I recall they were black spheres. They had a dozen or more transducers that I think I was told were Pioneer car speakers. I think they used speakeron connectors and stood on three black metal rods that mounted to a plate.
Dont try this at home:
Old 17th October 2003, 01:23 AM   #7
purplepeople's Avatar
Seems that you are describing a black VW Beetle MkII set up as a boom car. How many Pioneer speakers again?
:)ensen.
Those who claim to be making history are often the same ones repeating it.
Old 17th October 2003, 10:51 AM   #8
Coolin's Avatar
Default Looks like an interesting project with..
a lot of 3 or 4 inch cheap HQ Tangband drivers
Maby with a sub.
The soundspheres look simular except for the lack of drivers on the sphere.
Has anyone ever heard a omnipolar system wrt imaging?
CO
Old 17th October 2003, 11:35 AM   #9
Pjotr's Avatar
Hi Coolin,
I know of a real existing spheres but have no pictures. Those are located at the acoustical department of the technical university in Delft for demonstration purposes. And indeed over 2 feet diam and completely covered with 10 cm full range speakers. How do they sound? Well for large orchestra work these sound great but a single singer sings with a mouth of over 2 feet wide
Cheers
Old 17th October 2003, 11:48 AM   #10
Pjotr's Avatar
He found! They have made a new and smaller one:
Larger picture (145 kB)
Transcendent OTL T8 Vs. Atma-Sphere M60 Tyimo Tubes / Valves 64 6th October 2010 11:16 PM
Sequerra Metronome, anyone remembers it? Sylver300B Multi-Way 3 11th May 2008 03:23 AM
Constructing a sphere... Rocky Multi-Way 18 3rd November 2006 03:26 PM
10 - 16 ohm project for Atma-Sphere OTL amp j.burtt Multi-Way 2 8th May 2006 05:34 PM
Page generated in 0.10970 seconds (81.17% PHP - 18.83% MySQL) with 11 queries
